320 Sleeve Hitch Questions
5 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 11, 2014 - 10:55 AM
I know its a vertical shaft engine but im sure there is a sleeve hitch option.  Does anyone have a picture of one?  id like to know how it lifts and lowers.   Thanks
#2 hdg4400 OFFLINE
hdg4400
  • 283 Thanks
  • 348 posts
Posted April 11, 2014 - 11:27 AM
BairleaFarm:
Don't know if this will help, but here is a set of diagrams for making an Integral Hitch (what JD calls them). Not sure just which tractors this will mount on.
Attached File  93071-BM15764_INTEGRAL_HITCH_SQUARE.pdf   1.6MB   88 downloads
Harlan
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 11, 2014 - 12:36 PM
Thanks.  That wont work for this one.  I don't have the hump between your legs to run the lift rod,
#4 JDBrian OFFLINE
  • 9,609 Thanks
  • 14,144 posts
Posted April 11, 2014 - 03:40 PM
In JD speak sleeve hitch is an Integral Hitch. The correct one for those tractors is BM17626. If you go to JDParts.com and do a model search for the 320 then do an alphabetical search you'll find it under H for hitch.
You may also need lift handle extension BM19690
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 11, 2014 - 05:37 PM
I stand corrected hdg. There is room for a lift rod under the hump.
I've got a hitch I could easily mount to this but I wonder the durability of the rear. It looks awful small.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 11, 2014 - 05:38 PM
Of course it doesn't matter because this stupid thing is still making batteries leak.
