Ntm Heavy Hauler
4 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,286 Thanks
  • 2,682 posts
Posted April 11, 2014 - 09:12 AM
Picked up a new to me heavy hauler yesterday off CL.  It's a slightly used, though faded some (been setting outside all winter), JD 17P cart:
It'll be used mostly for sawdust, leaves & firewood.  One tire is leaking through the sidewall, so tubes are in order, otherwise just needs a good cleanup!
I've had a 10P for a few years & like it, just wanted a "big brother" for it.  Also have a couple steel carts if I need to dump something like dirt, etc.  ~~  Lowell
  • tinbender7, bgkid2966 and A.C.T. have said thanks
#2 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted April 11, 2014 - 09:25 AM
Good score!
  • grnspot110 said thank you
#3 JDBrian ONLINE
  • 9,643 Thanks
  • 14,158 posts
Posted April 11, 2014 - 10:12 AM
Nice cart. That's a big bonus to plastic. It won't scratch and then rust up on you if left outside.
#4 glgrumpy ONLINE
  • 8,722 Thanks
  • 7,977 posts
Posted April 11, 2014 - 03:24 PM
People actually use JD carts???  Oh, plastic.......carry on!
#5 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted May 20, 2014 - 05:54 PM
with what i can load in one of my trailers i could crush that with half what i can haul in the smaller of the two but one of those would be nice for around the yard, btw the smaller trailer is 30 in wide and 44 in long with 22 inch sides and has hauled a calculated 1850 lbs of broken concrete ,weight may have varied based on water content ,the bigger will hold one cubic yard of 2b stone and you can pull both with most gt's
