Working On The Ht23
3 replies to this topic
#1 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted April 10, 2014 - 07:08 PM
I bought this HT23 about a month ago, it was running several years ago then it was parked due to a broken belt.
Anyway, I stuck a battery in it and tried to turn it over, the starter spins and the gear engages, once the gear is engaged the starter keeps spinning and the gear stops.
I'm guessing something is broke in the starter?
Do I half to pull the engine completely out???
I got all of the bolts out that hold down the engine and I rocked it sideways but I don't think it's enough.
I got one starter bolt out, but I can't find any others, is it just the one bolt or is there another bolt that I am not seeing???
Any ideas would be great,
Thanks for any info
#2 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted April 10, 2014 - 07:45 PM
Started scraping more gunk and grease.
I found two more bolts, they were tucked under and hiding.
Looks like I will half to remove the 3 PTO belts so I can rock the engine further
Edited by BTS, April 10, 2014 - 07:46 PM.
#3 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted April 10, 2014 - 08:05 PM
Your going to have to lift the engine some to get it out,and ya there are 3 bolts holding in the starter,they  are a pain to change
  • BTS said thank you
#4 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted April 10, 2014 - 10:00 PM
Thanks,
Finally got the 3 bolts out and the starter is slid back all the way.
I now need to try and get the PTO belts off, any tricks or ideas?
looks like I can slide the tensioner back a little to get them a little looser but they are still about to tight to get off.
I'll look into it more tomorrow, it got dark on me tonight and I didn't have much time to look at it.
Thanks again
