Deere Stx38 Not Starting
14 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 09, 2014 - 09:22 PM
this is my neighbors  STX38
it has been setting few around 5 years in his shed
I like working on the 110's and the 200's series garden tractors
the STX38 is new to me
what I have done so far
checked the tank - empty
checked the carb fuel bowl - clean
checked the valves - not sticking
battery in dead - using one of mine
it acts like it wants to fire - but it did not
checked the spark - good blue spark
checked the fuel  - new fuel
got a new spark plug - set the gap
cleaned the flywheel -magnets and the ignition module - had rust on both
it pops a little
checked the muffler - removed it
the pipe going the the muffler is broken off
I think because one of the bolts holding it was gone
getting it fixed - before I try again
I am getting gas to the spark plug and good spark
there is not much to check
the CV12.5S sure is different from the K181, K241, K301, and the K321
I sure like working the K series a lot more
I have working on several B&S 5 hp and have no problems with them
is the flywheel key the same as on a B&S?
if it is broken and bent a little than it would not start and run
checked Deere part site and they state that the shaft key is Alloy not steel like the K series
I hope it is the shaft key - that would be too simple
can anybody get me going in the right direction to get it running again
thanks
#2 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted April 10, 2014 - 07:44 AM
Have you tried spraying carb cleaner in it when you crank it?  Or a bit of gas in the carb?
#3 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 10, 2014 - 11:40 AM
Travis
Yes I have tried a little gas in the carb
after cranking for a while I checked the plug and it is wet
I quess I have to pull the flywheel and check the shaft key
  • Trav1s said thank you
#4 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted April 11, 2014 - 07:44 AM
I think you are onto something with the key on the flywheel.
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted April 11, 2014 - 10:38 AM
Attached File  240.pdf   5.6KB   47 downloads Attached File  241.pdf   5.86KB   38 downloads Attached File  237.pdf   44.06KB   34 downloads
Hello lyall, this is help from the official Answer Center / Ask John Deere - Engine Will Not Start (Lawn Tractor) site. In the Answer Center you'll find answers for different questions
  • lyall said thank you
#6 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 11, 2014 - 01:54 PM
thanks Wolfgang
downloaded the files and read them
it was no help
I check the mag gap - .010
plug at .040
gas is new
gas on the plug - so I know it is getting gas
checked the spark - it is good
tried starting fluid - pop or two - but does not start
battery is full charged
I did put in a new shaft key - the old one is broke
I do not what else to try
need more help!
thanks
#7 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted April 11, 2014 - 02:00 PM
Carbon build-up on a valve preventing it from fully closing?  Bad headgasket?  Pull the head and take a looksie would be my next step.
#8 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted April 11, 2014 - 02:39 PM
that's not good, lyall. here some simple thoughts, you had certainly, too:
you need only three things, to run an engine: fuel, air and an ignition spark - and if all this parts handle in the right time, something must happen. the next step can only be to proof the proportions of the parts (sorry, but it's hard to me to find the right words).
i think the only way to find this failure is to suspend the things, that are ok.
is the right voltage at the spark...
has the engine compression...
yep, basic questions, but... I've no more ideas
Edited by jd.rasentrac, April 11, 2014 - 02:40 PM.
#9 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 11, 2014 - 03:26 PM
would a blown head gasket stop it from starting
what I am thinking if the head gasket is blown the compress would drop so that is would not start
there is a blow by from under the cylinder
too low compress I do not think it would start
what do you all think about it
thanks
#10 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted April 12, 2014 - 05:27 PM
If the leak was bad enough it could prevent it from starting. I am still thinking carbon that prevents a valve from closing.
#11 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 18, 2014 - 09:10 PM
got a new head gasket
the old head gasket about 1" of the head gasket was gone
got the the new head gasket on and the it all put back together
started and is running
but it is over revving
I will work on it tomorrow
have to get a new battery for my laser tach
#12 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted April 19, 2014 - 05:24 PM
How goes today's progress?
#13 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 19, 2014 - 10:16 PM
can't stop it from over revving
at full throttle is is just under 5000 rpm
at half throttle it is around 3500 rpm
at low ldle it is around 1250 rpm
set the governor per the manual
still no change
called a friend that sold and repair Cubs
he said it might be the governor spring
but he said I can set the governor back a little and keep checking as I back off the governor and see if that slows the rpms down
looked up the governor (part number 1204305-S) and there are no springs for it just the weights
so I hope by adjusting the governor arm back a little will fix the problem
oh this is going to be fun
oh the stx38 has a safety switch for the seat so I put a 50- lb weight on the seat so that I can work on the motor
  • jd.rasentrac said thank you
#14 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 20, 2014 - 07:06 PM
will today I got the governor set.
that was after a half hour of trying
it went below 3600 rpm and tried again back up to 4300 rpms
keep trying until I got it close
final rpm at 3450
then I was going to test drive it
I first time working on a hydro
the neighbor set it to free wheel, so we could tow it
so I had him show me what he done
he set it back and he drove it around
he was happy like a kid, it was just sitting in his shed for the last five years
he went home and mower a little bit
 and came back with a check for me and said that is the best it has ran in years
told him that I had to replace the head gasket, the key for the flywheel and a spark plug
I did clean up the oil and dust on it and it is looking great for a 95 stx38
#15 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted April 20, 2014 - 08:06 PM
Glad you got this one figured out!
