Ridemaster Restoration Begins!
119 replies to this topic
#106 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted July 29, 2014 - 08:47 PM
Boy Doc., it sure looks great. You have done a very nice job!! :thumbs:
#107 Bill56 OFFLINE
  • 844 Thanks
  • 2179 posts
Posted July 30, 2014 - 02:31 AM
Looks good Brian! The decals really set it off.  :thumbs:
#108 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 6034 Thanks
  • 2244 posts
Posted July 30, 2014 - 06:35 AM
That ridemaster really looks good with the decals on it.
The stripe decal was a new one to me also.  I had never seen one on a ridemaster until Jerome came across the one he has.
It does seam strange that the factory would only put it on the one side ?
Was that decal that you have over the serial number plate on all the Ridemasters or just on later models ?
Edited by jdcrawler, July 30, 2014 - 06:47 AM.
#109 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted July 30, 2014 - 08:42 PM
The Patent decal is for the later Ridmasters
My strip is only on the right side sitting on the tractor.  R-4765, R-5339, and R-6403 all have the stripe.
  • Bolens 1000, LPBolens, Texas Deere and Horse and 2 others have said thanks
#110 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 02, 2014 - 12:16 PM
All Finished!!
I'm still debating whether I should pull up that stripe on the left side, with it being stuck on there so well .......
Have I mentioned these things are really fun to drive? :D
  • olcowhand, Texas Deere and Horse, jdcrawler and 3 others have said thanks
#111 Bill56 OFFLINE
  • 844 Thanks
  • 2179 posts
Posted August 02, 2014 - 01:23 PM
Absolutely fantastic Brian!!!
  • Bolens 1000 said thank you
#112 BowDown OFFLINE
BowDown
  • 623 Thanks
  • 613 posts
Posted August 02, 2014 - 01:27 PM
That is an awesome restore. Congrats!
Sent from my Z30 using Tapatalk
#113 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted August 02, 2014 - 01:34 PM
Very nice Doc!  :thumbs:
#114 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted August 02, 2014 - 02:40 PM
That looks fantastic! Nice job!
#115 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted August 02, 2014 - 04:59 PM
:thumbs: Brian!
Nice job!  :worshippy1:
Do you have the "A-frame" to mount a blade on the front?  ....I happen to have a front blade. :poke:
As for the broken start pulley - I saw similar cast-iron pulleys on Shaw tractors, but I'm not certain of the width of the belt groove.  ....I'm sure yours could be repaired if you can't find another.
#116 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 02, 2014 - 05:03 PM
:thumbs: Brian!
Yes, I do have the "A" frame but did not blast it this time around :D
I hope I can get that blade before it goes up for sale :D
How could that Cast Pulley be repaired? I do not have any of the missing pieces so what would you use???
#117 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted August 02, 2014 - 05:08 PM
I would not repair the pully because of safety...
Bruce do you have the full blade?  Is it NOS? If it is would be great to see.  I dont need myself with aready haveing two.
#118 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 5122 Thanks
  • 2911 posts
Posted August 02, 2014 - 05:15 PM
It's already sold!
I could tell you, but then I'd have to kill you!
.Just kidding!  ....(I need to add this disclaimer to comfort the sensitive types!)
It appears the break in your pulley does not go into the hub area (large diameter hole).
I think a donor piece of cast-iron (from a suitable pulley or such) could be brazed onto your pulley, after making a clean, straight cut on your pulley.  ....Once that is done, the pulley can be re-machined to match the contour & diameter of the un-broken area.
I would be willing to attempt such a repair if you can't find someone locally.  ....Of course, I offer no guarantees! :(
  • Bolens 1000 and Texas Deere and Horse have said thanks
#119 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 5122 Thanks
  • 2911 posts
Posted August 02, 2014 - 05:18 PM
Bruce do you have the full blade? As far as I know.
Is it NOS?   No.
#120 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 6034 Thanks
  • 2244 posts
Posted August 03, 2014 - 04:33 PM
Having worked in the machining industry all my life, I'm going to have to agree with Jerome on this.  Brazing a piece onto the pulley is dangerous.
First off, brazing is a soft weld that is subject to cracking with vibration ( and these Wisconsin engines do vibrate ).
Cast iron itself is subject to cracking and it is not uncommon for it to crack right alongside the edge of a weld.
The way I would repair it is to machine a complete front flange on the lathe and then cut the notches for the rope.
Then chuck the pulley up in the lathe and cut the existing flange off so you have a diameter on the end that the new flange fits on tightly.
The new front flange can then be pressed onto the pulley and welded in place.
Edited by jdcrawler, August 03, 2014 - 05:22 PM.
  • Texas Deere and Horse and Bruce Dorsi have said thanks
