Need Some Help On A Briggs
12 replies to this topic
#1 UncleWillie ONLINE
  • 15,669 Thanks
  • 8,761 posts
Posted April 09, 2014 - 03:15 PM
I went out and tinkered with the TroyBilt today. With out the spark plug it turns over just fine. Put the plug in it and it barely will turn over by hand.
Any Ideas?
  • hamman and boyscout862 have said thanks
#2 farmerall ONLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted April 09, 2014 - 03:25 PM
I think that happens when the valves need adjusted. I have no experience with this problem but I've heard of other people have similar problems.
#3 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted April 09, 2014 - 03:32 PM
Is there a compression release on this model if so might not be working.
By the way I like the fuzz on your head :D I can't grow any hair on my head so your one up on me in that department.
#4 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted April 09, 2014 - 03:37 PM
It's especially true on the OHV engines. It opens the intake slightly for comp release.
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 09, 2014 - 03:40 PM
Check the valves like Doug and Farmerall suggested.  Make sure they are opening and closing.
#6 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,130 posts
Posted April 09, 2014 - 03:47 PM
Battery good, starter good, bad engine ground ? I had a starter for my snow blower once that turn over great on the bench put would not turn the engine fast enough to start engine. Just wondering, Noel
#7 UncleWillie ONLINE
  • 15,669 Thanks
  • 8,761 posts
Posted April 09, 2014 - 03:53 PM
I hooked it directly to the battery in the Hemorrhoid with jumper cables.
I will pull the valve cover off tomorrow and check it.
  • propane1 said thank you
#8 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted April 09, 2014 - 04:21 PM
My neighbor had nearly the same problem with his troybuilt. He had to have a new cam and push rods put in which the parts and some labor was covered by Briggs. He had problems for a year or so. He would adjust the valves and it would run well for a while and have to have it done again. He and I did this several times. He took it to a dealer and they charged him $350 to fix it. had it for over 6months. Got it back and it did it again. This time when he took it back he called Briggs and complained. This is when they put a new cam in along with the new push rods. After this it ran well but he had no confidence in it. He gave it to his longtime friend has bought him a new Comercial Husqvarna Zero Turn with a Kohler motor in it. He did get $100 back from briggs.       When it was acting up it wouldn't turn over if there was a spark plug in it.        Roger.
#9 CRFarnsworth ONLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,143 posts
Posted April 09, 2014 - 04:23 PM
Reset the valves. It'll turn over and fire right up.
Check on you-tube for a video .  you'll be surprised at  the difference.  I recently experienced this with the same engine.  The valve clearance loosens up and there isn't any compression release.  Rick
There is a good explanation on youtube.   search for (how to adjust valves) Fix hard to start lawn tractor with ohv
by donyboy73 .    It's a two part video and he explains the how and why pretty well.
Edited by CRFarnsworth, April 09, 2014 - 04:36 PM.
  • hamman and UncleWillie have said thanks
#10 UncleWillie ONLINE
  • 15,669 Thanks
  • 8,761 posts
Posted April 09, 2014 - 05:15 PM
I will watch that after I get through this WWII documentary on German Jets.
#11 UncleWillie ONLINE
  • 15,669 Thanks
  • 8,761 posts
Posted April 09, 2014 - 06:16 PM
The video is exactly what mine is doing. I will check it out tomorrow.
#12 CRFarnsworth ONLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,143 posts
Posted April 10, 2014 - 06:37 PM
I read on your other thread that you got it running.   :thumbs:    Amazing what a difference that a few thoundsandths of an inch will make.
Rick
  • IamSherwood said thank you
#13 UncleWillie ONLINE
  • 15,669 Thanks
  • 8,761 posts
Posted April 10, 2014 - 07:29 PM
Yeah it was supposed to be at .003. it was out to .020+
