Cleaning The Garage
9 replies to this topic
#1 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted April 08, 2014 - 01:48 PM
The lights at the side of the door are to tell my friends that if they are on then I am  in the Workshop or around there somewhere.
Decided to move everything outside today and use the leaf blower to clean the garage and workshop. I lined everything up outside and took a few pic of all the Projects. So here they are. The Choremasters will each receive a different paint job representing a different model of Garden Tractor and also a matching colors sulky.
The Case Electric needs some decals and a different hood. I want the hood that was straight on both sides. I am also looking for a 24 volt charger that will fit in the space the gas tank used to be.
The Massey needs a little more body work and also I finally got the motor running but it leaks oil out of the valve breather. (really getting tired of the troubles with the Massey).
The Simplicity was a 100 dollar purchase and I put a battery in it and it runs fine. Since buying it I also picked up a snow blade and a snow blower for it. The Springboard seat is for a future Sulky build.
The  next topic will be the newest challenge of combining two things to make one unique ride. :rocker2:
Edited by Traill95, April 08, 2014 - 01:51 PM.
  • Bolens 1000, DH1, Alc and 9 others have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 08, 2014 - 03:07 PM
Nice bunch of tractors. On the Case electric do you drive the hydraulic pump with an electric motor or do you direct drive the rear end with the electric motor?
  • CRFarnsworth and Traill95 have said thanks
#3 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted April 08, 2014 - 04:06 PM
It has a 24 volt electric motor with a pump that drives the rear end.
#4 CRFarnsworth ONLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted April 08, 2014 - 04:14 PM
I can answer that question. It is powered by an electric motor/pump combination that pressurizes the normal valveand hydraulic system of the Case tractor. Similat to what is in these pictures.   Rick
  • chris m and Traill95 have said thanks
#5 KC9KAS OFFLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
Posted April 08, 2014 - 06:23 PM
Nice collection of GT's!
Thanks for the photos.
  • Traill95 said thank you
#6 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 08, 2014 - 07:29 PM
Nice heard for GT's! Thanks for sharing the pics!
This also must mean that warmer weather is finally coming :dancingbanana:
#7 HDWildBill OFFLINE
  • 8,984 Thanks
Posted April 08, 2014 - 07:37 PM
I really like that Case Electric. but all of them look good.
#8 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted April 08, 2014 - 07:38 PM
Yeah,,,what he says and shows. :thumbs:
#9 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted April 08, 2014 - 08:53 PM
Don't give up on your Massey! Have you done the restoration work? It looks good!
#10 BowlBuilder OFFLINE
BowlBuilder
  • 485 Thanks
  • 465 posts
Posted April 10, 2014 - 03:08 AM
What kind of run time do you get out of the Case with two batteries?  Very interesting.  I would love to see more.  Do you have any old threads on this tractor?
