I think I got my own diesel !!
37 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted January 17, 2011 - 10:30 PM
If all goes well, I will pick up my new to me diesel engine this weekend or first of next week. Its a 14hp kubota.
  • twostep and SupplySergeant have said thanks
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted January 17, 2011 - 11:31 PM
Good for you!!! I see another conversion in the making.
That area of the site is getting fuller by the minute. :D
#3 mjodrey OFFLINE
Posted January 18, 2011 - 05:22 AM
That's great,you just can't beat those little Kubota engines.
#4 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted January 18, 2011 - 09:01 AM
We'll be watching - hope you get it. Do you have a recipient tractor lined up yet? If it is a WheelHorse will your new creation be a KubeelHorse?
JN
#5 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted January 18, 2011 - 09:36 AM
:dancingbanana::dancingbanana::dancingbanana::dancingbanana: WooHoo.....Texas Diesel! You may have to change your member name! :smilewink:
#6 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted January 18, 2011 - 09:42 AM
Would it be a Z602 twin?
  • 14,889 Thanks
  • 15,514 posts
Posted January 18, 2011 - 11:01 AM
Made the deal on the donor tractor, its a kubota TSH1600. The engine is a 2cyl. 13.5 Hp.. Here is the specs. of the engine-
Engine Model:Z482
Head Bolt Torque:32
Tractor Model:T1600
Main Bearing Case Bolt 1 Torque:12
# of Cylinders:2
Main Bearing Case Bolt 2 Torque:23
Displacement (CC):479
Rod Bolt Torque:23
Displacement (Cu In):29.3
Flywheel Bolt Torque:44
Bore (MM):67
Rocker Arm Bolt Torque:8
Bore (In):2.6
Compression (PSI) Standard:450
Stroke (MM):68
Compression Lower Limit:325
Stroke (In):2.6
Engine HP (Net):13.5
Now all I have to do is decide which tractor to put it in, I have a few options-
1. 140 H-3 John Deere
2. C-series W.H.
3. Home made forklift- built from a 316 Jd. running backwards.
If I you a W.H., I will either have to cross mount engine or I could use a D-series setup for powertrain on a C-series frame.
I really think the easist repower would be the 140.
I would love yall's input, Brian
#8 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted January 18, 2011 - 11:02 AM
Boss, thats very good, I will remember that one !!
#9 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted January 18, 2011 - 11:04 AM
I think you should buy a machine that has a bad motor instead of taking one running out. A good canidate is the jd 400 or bolens large frame with the mechanical engagement pto
#10 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted January 18, 2011 - 11:12 AM
Mike,
I have several non running canidate tractors, I wish I did have a 400 series Jd. or a 400 series Case.
Thanks, Brian
#11 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted January 18, 2011 - 11:14 AM
On the WH, you could always use a 90 degree gearbox, like used in older Allis & Simplicity tractors.
#12 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
What non-runners do you have?
#13 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted January 18, 2011 - 11:15 AM
BTW, my Kubota G4200 tractor has the Z482....darned good diesels!
#14 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted January 18, 2011 - 11:25 AM
Daniel, Here is a list, LOL
Wheel Horse- Bronco14, Raider12, 1277, 416-8Kolher, C-160, (D-200, at my folks place in In.)
Jd.- 3 140's, 2 120's, 4 112's, 2 110's, 316 series 2
Do you think this engine will out perfom a k321s 14hp. kohler, or maybe even a 16hp. Onan?
These are my parts machines, besides what I have listed as runners.
Edited by Texas Deere and Horse, January 18, 2011 - 11:32 AM.
#15 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted January 18, 2011 - 11:31 AM
If I use a 90degree gearbox on a wheel horse, I won't be able to use the pto in the stock location.
