Lgt 165 Engine Apart Some.
13 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted April 07, 2014 - 05:02 PM
Took the head off and some other things.  Anybody have a rule of  thumb on what valve guide gap should be? I can't feel much but I am just a back mechanic, so just wondering your thoughts. Noel
  • superaben said thank you
#2 boyscout862 ONLINE
  • 12,551 Thanks
  • 9,044 posts
Posted April 07, 2014 - 07:30 PM
These manuals will help.
http://gardentractor...service-manual/
http://gardentractor...ine-rebuilding/
Good Luck, Rick
Edited by boyscout862, April 07, 2014 - 07:32 PM.
  • propane1 said thank you
#3 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted April 08, 2014 - 05:06 AM
Looks like the Head gasket was fine on it. That carbon buildup is typical in those engines. What does the cylinder wall look like?
#4 Sprint 6 OFFLINE
Sprint 6
  • 227 Thanks
  • 293 posts
Posted April 08, 2014 - 07:36 AM
Looks like it was burning some oil, since the side of the piston is washed clean.  I bet it has a broken ring, my LGT165 did.  They don't get kept clean due to the closed sides and run hot and pinch the rings.  Mine had a gouge down the cylinder where it broke.  Mine is now bored .020 over with new valves and rod.  The increase in power was amazing, and I thought it had power prior to the rebuild.  I got my kit from ebay, I was skeptical of quality, but it has run a season now with no problems.
#5 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted April 08, 2014 - 05:00 PM
No broken rings. Every thing seems to be reasonable shape, All though I am only back yard mechanic. So I am going to get piston, rings, wrist pin and rod for it. From what i can see every thing is still standard size.  Any body know any thing about the balance gears? Some guys around here take them out when rebuilding. I am not a fan of removing some thing that was in there from new. They must serve a purpose. Noel
Any information greatly appreciated, Thanks
#6 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted April 08, 2014 - 07:20 PM
Yup those balance gears serve a purpose... To completely render a perfectly good block and crank junk when they fail!! Throw them away, you really won't notice any difference.
#7 Sprint 6 OFFLINE
Sprint 6
  • 227 Thanks
  • 293 posts
Posted April 09, 2014 - 07:29 AM
For what its worth, my balance gears and bearings where in good shape, so I put them back.  Your experience may vary.
#8 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted April 27, 2014 - 04:32 PM
Just wondering how the engine is coming along?
Also, were the piston rings gaps in the picture staggered, or were they turned before the picture?
#9 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted April 27, 2014 - 04:45 PM
Just got parts yesterday and in the painting stage. Will be couple of weeks before its back together. Want to take my time, not a professional engine builder. So many bolts and stuff, don't want any thing left over. Thanks for asking, Noel
Rings got turned before picture, oil ring worn bad, compression rings not to bad.
Edited by propane1, April 27, 2014 - 04:45 PM.
  • stiemmy said thank you
#10 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted April 27, 2014 - 04:57 PM
SUPER!! Keep us posted.
#11 AlleyKatz51 OFFLINE
AlleyKatz51
  • 41 Thanks
  • 35 posts
Posted April 27, 2014 - 08:31 PM
My experience with the syncro-balancer is swaping out engines with half the block blown away when a balancer gear explodes. Even had a customer get his shoe blown off.  This was on the A-C 300/400 series but these are the same thing. If you leave them in you need to inspect them super good  for being loose or any sign of damage. Also they need to be properly timed to the crankshaft which we had a special tool for. Good luck.
Chuck
Edited by AlleyKatz51, April 27, 2014 - 08:35 PM.
#12 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted April 28, 2014 - 05:09 PM
More say take them out than leave them in , so out they go.  Noel
#13 AlleyKatz51 OFFLINE
AlleyKatz51
  • 41 Thanks
  • 35 posts
Posted April 28, 2014 - 07:12 PM
A little more info if you do leave them out. The balancer does smoothen out the engine at low RPM. What I noticed mostly was that at idle and a little above it will act a little like a Harley at idle then smoothen out as the RPM is raised. My LGT 125 acts that way without the balancer. It isn't any problem and gets rid of what can be a serious problem.
Chuck
#14 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted April 28, 2014 - 08:22 PM
Just curious, I keep seeing these threads with people saying yay more than nay about these gears supposedly BLOWING up, or exploding, but I have only seen one pic!!!!!! I would be willing to guess that there are STILL more running, than scrapped Kohler K series engines than you might think. Are there any legitimate pictures of kohlers that have NOT been spun to an RPM that will reach the moon, and if so, how many? Can't be much, cause I personally see alot of originals still goin! ( kinda makes me think of the flywheel exploding myth , "YEA I saw one, but only in pictures") Rod failures are more common than anything.
I personaly own 6 (six) Kohlers, ALL of I personally purchased used due to the FACT THAT I AM 39 years old, and all, but 1 of them are older than I am. NOT ANY of the engines that I own, do I know the complete history on, or IF regualr oil changes were done????? If it works, leave it alone. What we don't hear, is the 12 year old kid, who just got into pulling, tried getting a little more from the throttle , and then WHAT? BOOM.
If ya don't rev the snot out of it, keep regular maintenance, it should last INDEFINATELY! PERIOD. Just my take on this.
Edited by stiemmy, April 29, 2014 - 04:34 AM.
