What Fluid To Use In The 318 Rear? And Where Is The Fill Hole.
8 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted April 07, 2014 - 04:20 PM
I need to know what fluid to use in the rearend of my 318, something that isn't John Deere brand.
Also, where is the fill hole for the rearend fluid.
#2 olcowhand ONLINE
  • 42,352 Thanks
  • 31,788 posts
Posted April 07, 2014 - 04:26 PM
I think the fill tube is under the hood next to the dash, left side as sitting in seat.  You can use any good hydraulic/transmission fluid (NOT straight hydraulic oil), which you can find at TSC or similar ag supply stores.
#3 13jac1316 OFFLINE
13jac1316
  • 4 Thanks
  • 10 posts
Posted April 07, 2014 - 07:58 PM
i personally use atf in my 316 the fill hole is the tube on the left side toward the dash
#4 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted April 08, 2014 - 08:35 AM
Ok, so dextron would be ok to use??
#5 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted April 08, 2014 - 08:54 AM
I use Typt F ATF in mine. Here is a thread where it was discussed a little while back: http://gardentractor...ic-oil-for-318/
#6 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted April 08, 2014 - 04:19 PM
I am wondering if mine has Dextron in it right now, the fluid is red. :tapping_fingers:
#7 olcowhand ONLINE
  • 42,352 Thanks
  • 31,788 posts
Posted April 08, 2014 - 04:36 PM
Likely type F ATF, which is what the manual calls for for most of them.  There has been much discussion about this, so I went with the hydaulic/trans fluid.  I also personally use type F in my F935, which has the same hydro unit as yours.  I have also used the hyd/trans fluid.
#8 olcowhand ONLINE
  • 42,352 Thanks
  • 31,788 posts
Oh, and Dex III is ok as well, but not Dex II.
#9 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted April 09, 2014 - 08:27 AM
olcowhand, that is good to know on the dextron III
