Removing Driven Grease Fittings?
3 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted April 07, 2014 - 12:04 PM
Anyone know how to remove the grease fittings that are, I assume, driven in?  A couple of mine have a round base instead of the hex base.
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,929 Thanks
  • 4,996 posts
Posted April 07, 2014 - 03:06 PM
Can you get on them with a pair of visegrips and twist and pull them out? If they won't wiggle back and forth and pull out maybe try unscreing them anyway. Maybe they thread and jsut don't have flats or have 2 flats on the rounded parts?
#3 glgrumpy OFFLINE
  • 8,618 Thanks
  • 7,926 posts
Posted April 07, 2014 - 03:13 PM
Beware if you have real short base fittings like used on thin tubes or such with shafts thru them, that there may Not be enough metal there to use a screw-in type. It will hit the shaft inside and cause binding or lock it up. You would have to take a 1/4' nut and weld on to the outer tube to use standard grease fitting there. Not sure how they got them in when new, but I assume it comes installed on a new part if one was still available.
  • Alc and New.Canadian.DB.Owner have said thanks
#4 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted April 08, 2014 - 05:32 AM
Have you tried a claw hammer?
