Older Ford Hydrostatic, Any Help Appreciated.
drain fill plugs filter?
9 replies to this topic
#1 davidj927 OFFLINE
davidj927
  • 22 Thanks
  • 20 posts
Posted April 07, 2014 - 11:27 AM
Hello, I have to say I'm new to this, and would appreciate any info offered! I inherited a Ford #53265-13684 tractor. It does have the Kohler engine, though I don't know hp. I have engine running good, but hydrostatic trans is very weak, barely moves. Does anyone know what trans this is? What year tractor it is? Location of fill and drain plugs on trans? Is there a filter that might be clogged on trans? Any idea what oil trans uses? I know this is a lot of info I'm requesting, and any help would be MUCH appreciated.
Will changing trnsmission oil possibly help in motivating this old gal? It certainly looks like it could be a useful piece of equipment around the homestead! Thanks, Dave
#2 davidj927 OFFLINE
davidj927
  • 22 Thanks
  • 20 posts
Posted April 07, 2014 - 11:34 AM
  • propane1 said thank you
#3 New.Canadian.DB.Owner OFFLINE
  • 2,285 Thanks
  • 1,475 posts
Posted April 07, 2014 - 11:43 AM
Do you have the tow / drive lever in the correct position?  All hydros have  a mechanism that allows you to move the tractor without the engine running and without damaging the transmission.
P.S. Welcome.  Some Ford savvy people will be along shortly.
  • boyscout862 and davidj927 have said thanks
#4 boyscout862 OFFLINE
  • 10,505 Thanks
  • 7,927 posts
Posted April 07, 2014 - 11:46 AM
Welcome to GTT. Pistures will help us identify your tractor and see any obvious problems. You can download the manual from our Manuals Tab(3 free per day) and see what it says. Good Luck, Rick
  • davidj927 said thank you
#5 davidj927 OFFLINE
davidj927
  • 22 Thanks
  • 20 posts
Posted April 07, 2014 - 11:55 AM
I wasn't aware of tow / drive lever, although tracto does move back and forth, just very weakly and with little or no force, barely pulls itself...But thanks!
PS: I moved every lever I could find !   :-)
#6 Rock farmer ONLINE
Rock farmer
  • 1,131 Thanks
  • 1,187 posts
Posted April 07, 2014 - 01:24 PM
That should be a 1970 - 1971 LGT 145 open side made by Jacobsen.
14 horse power Kohler
It will have a filter canister right in front of the hydro unit under the center of the tractor.
You don't want to replace it if you don't have to.
They cost about $100.
Joe
#7 Oldford OFFLINE
Oldford
  • 842 Thanks
  • 589 posts
Posted April 07, 2014 - 02:58 PM
Can you post a pic.  Depending on year may be a bypass knob to right of battery box should be turned full clockwise to drive.  Check your fluid level should be within 1" of top.  Again depends on year your# puts it in transition years as Joe said. pic would help show what you have good luck
also if belt is slipping trans won't push full power could be weak spring try pulling lever backwards with top of foot
Edited by Oldford, April 07, 2014 - 03:00 PM.
#8 propane1 ONLINE
propane1
  • 6,809 Thanks
  • 3,480 posts
Posted April 07, 2014 - 03:05 PM
If its an LGT 145 like rock farmer say it is, then it would high/low range differential with a neutral, so no tow valve in this tractor. I would check fluid level.  Noel
  • Chopperhed and davidj927 have said thanks
#9 TomLGT195 OFFLINE
TomLGT195
  • 3,018 Thanks
  • 2,344 posts
Posted April 07, 2014 - 03:06 PM
Welcome to GT Talk,
:wewantpics:  they would help. Tom
#10 olcowhand OFFLINE
  • 36,869 Thanks
  • 30,149 posts
Posted April 07, 2014 - 03:16 PM
My search said 140, but I'm no Ford guy.  A pic or 2 would certainly confirm model.
