Hydro - Gear Rotation Questions.
6 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,521 Thanks
  • 15,400 posts
Posted April 06, 2014 - 10:34 PM
When I picked up the Bush Hogs at Burl's house, he had some questions about rotation that I couldn't answer. Maybe you don't know this fact but the Bush Hog Hydrostatic tractors used the same Hydro-Gear unit as the early JD 140 did, but with reversed rotation. My question is, is there a way to switch rotation on these units?
#2 chris m OFFLINE
chris m
  • 3,315 Thanks
  • 4,047 posts
Posted April 07, 2014 - 12:42 AM
If I remember correctly Daniel has talked about this a few times over the years?? I think this is one of the ones you have to flip the charge pump, not sure if it was determined that the swash plate needed flipping to??
I do know that Daniel will set us in the right direction though :D
#3 nbent OFFLINE
nbent
    customizer
  • 650 Thanks
  • 529 posts
Posted April 07, 2014 - 02:29 AM
if it has a similar transmission to the sundstrand 90 thats in a 318 jd then to change the rotation you have to change the charge pump areound and maybe do a few other things. im trying to figure out what all is required to change the direction for one of my projects.
#4 Texas Deere and Horse ONLINE
  • 14,521 Thanks
  • 15,400 posts
Posted April 07, 2014 - 10:03 PM
I will do some looking around and see what I can find that Daniel posted.. :thumbs:
#5 olcowhand OFFLINE
  • 37,719 Thanks
  • 30,340 posts
Posted April 08, 2014 - 04:23 PM
Got some time to look at the schematics on these units.  It would appear that the housing plate that contains the gyrotor charge pump could be rotated 180* so it could be ran the opposite rotation, but I can't confirm as I've not been into one.  Not nearly as simple to get at the charge pumps on these as with many hydro's though.
#6 olcowhand OFFLINE
  • 37,719 Thanks
  • 30,340 posts
Posted April 08, 2014 - 04:31 PM
Also, on the brassy looking thrust face plate that the pump's cylinder end runs against...they almost always have 2 notches in the plate, for what reason exactly I'm not sure.  But when I reverse direction, I use a dremel or file to make the notches in the opposite ends.
#7 Texas Deere and Horse ONLINE
  • 14,521 Thanks
  • 15,400 posts
Posted April 09, 2014 - 12:35 PM
Thanks Daniel, Burl asked me and I had no idea what to tell him.
