Love Joy Coupling Source
8 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted April 06, 2014 - 07:48 PM
Well, while repairing the governor gear on my 442, I found the urethane spider was in pieces. The coupler halves had a little metal to metal contact but is not real damage. It just shined it up a bit. I was wondering on a source for one. It calls for a L099 spider. I've read a few things online about the replacement one is a L099/L100 and is thicker. I would rather just find a stock replacement. Any ideas?
Eric
Sent from my EVO using Tapatalk
#2 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 06, 2014 - 08:16 PM
I think McMaster Carr carries them.
  • dropped82 and superaben have said thanks
#3 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted April 06, 2014 - 09:53 PM
If your close to a Motion Industries they should be able to help you out.
  • dropped82 said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 06, 2014 - 09:56 PM
Will's the man!!
Any good industrial supply store that carries belts, hoses, bearings and the like (like Motion or Applied as has been suggested) should be able to help, too.
Ben W.
#5 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted April 06, 2014 - 10:33 PM
I will look into. Never heard of a motion industries but will do a little more searching. Thanks for the help! I've looked at
Surpluscenter.com and they only had the L099/L100 replacements which I've read is too thick. Hopefully one of those 2 leads you all gave will help. Thanks again!
Eric
#6 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted April 07, 2014 - 05:49 AM
Tractor Supply carries one, not love joy but identical. Check around, should be a fairly common part.
#7 Robert Webb OFFLINE
Robert Webb
  • 897 Thanks
  • 426 posts
Posted April 07, 2014 - 08:23 PM
http://stores.jrhydr....com/couplings/
#8 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted April 07, 2014 - 09:03 PM
If the spider is open center can you slide in a little on both shafts to make up difference in thickness. Thats a replacement from love joy so if that wont work for you put it on belt sander and thin it down keeping it as flat as possible.
#9 BowlBuilder OFFLINE
BowlBuilder
  • 485 Thanks
  • 465 posts
Posted April 08, 2014 - 04:23 PM
PM me your address and I'll drop a good used one in the mail for you.  It is a Lovejoy brand L-099 L-100 and was removed from a working 1985 448.  If it's too thick (which I don't believe it will be) you can modify it and not possibly ruin something you paid good money for.  It is in very good shape.  Will keep an eye out for a tiller in the area for you.  Not looking myself, already have one.
  • olcowhand and dropped82 have said thanks
