Question About Jd Models For Snow Plow
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,121 Thanks
  • 4,276 posts
Posted April 06, 2014 - 10:20 AM
Thinking about finding a snow plow for my JD140 H3. What models of tractors has the same plow that will fit a 140. Not easy to find plow, so if I knew other models will fit, it may help the search. And what is the model number for the plow?  Thanks, Noel
Also what are the holes in the rear fender deck are for??  Looks like it was done at the factory.  Never seen another one with the holes.
  • A.C.T. and larisaPn have said thanks
#2 jdslednut OFFLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted April 06, 2014 - 10:34 AM
Blade should be a model 54.  Same one fits the closed frame models 120, 300, 316 (Kohler), 314, 312, 317, probably a couple others I'm forgetting.  Not sure about the holes though.  Never seen one either.
  • propane1 said thank you
#3 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 06, 2014 - 11:59 AM
The 54 is the easiest and it fits the following tractors:
120/140
300/316K, 312/314/317, 316/318, 322/330/332.
Closed frame tractors = 120/140, 300/316K, 312/314/317
Open frame tractors = 316/318, 322/330/332
It is also possible to mount the 43 from the flat fender 110/112/200 series and then fab up a lift cylinder.  I don't know if it is possible to adapt the 100/200 series lift rod to work.
Edited by Trav1s, April 06, 2014 - 12:01 PM.
  • A.C.T. and propane1 have said thanks
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted April 06, 2014 - 12:53 PM
No clue on the holes, never seen anything that would go there except a pic of a homemade roll cage on one that was made into a forklift.
#5 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted April 06, 2014 - 02:03 PM
propane1:
Always wanred a front blade for my old 140. Actually cobbled together a center blade that raised and lowered with the mower straps.
If you do get the 54 blade, I have the OP manual and Parts Catalog for it scanned in that I could send you. Just let me know.
Harlan
#6 propane1 ONLINE
propane1
  • 9,121 Thanks
  • 4,276 posts
Posted April 06, 2014 - 02:07 PM
hdg4400. Thanks.  Noel
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,291 posts
Posted April 06, 2014 - 02:35 PM
Attached File  120-332_JD_Attachment_plate.pdf   100.66KB   91 downloads
Attached File  70-300_John_Deere_Attachment(dated_Nov74).pdf   260.74KB   49 downloads
  • Trav1s and propane1 have said thanks
#8 propane1 ONLINE
propane1
  • 9,121 Thanks
  • 4,276 posts
Posted April 06, 2014 - 02:43 PM
jd.rasentrac.  Thanks for the info. Noel
#9 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted April 01, 2015 - 09:27 PM
propane1,
Is that tractor by any chance a 1968 model year? Reason for asking is, it has the larger diameter steering wheel center cap. Just curious, that's all.
