Tractor Over Charging...
8 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 05, 2014 - 05:31 PM
The jd 320 is still over charging. The Kawasaki is running great but it's still causing the battery to spit acid. I've been meaning with it all winter and am out if ideas. Here are the volts. Low idle high idle and running full throttle with the pto engaged.
uploadfromtaptalk1396737086891.jpg uploadfromtaptalk1396737105078.jpg uploadfromtaptalk1396737113583.jpg
Sent from my SAMSUNG-SGH-I437P using Tapatalk
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 05, 2014 - 05:32 PM
Battery, starter, and regulator have all been changed with no effect.
#3 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted April 05, 2014 - 05:34 PM
Do you have a wiring diagram we can start from?
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 05, 2014 - 05:45 PM
I don't
#5 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted April 05, 2014 - 07:31 PM
I don't know how the regulator works on those newer tractors. The only thing that comes to mind is the ground connection. If the connection that the regulator uses for a ground reference is compromised in some way it could possibly cause an over voltage. At this point a diagram would be a big help.
  • Alc and superaben have said thanks
#6 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted April 05, 2014 - 07:36 PM
I have found something that may help. I'm sending you a PM.
#7 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted April 07, 2014 - 03:43 PM
You sure that is overcharge?  Cars put out 14.5 volts up or down some to charge battery, would think the tractors would be about same?  You say the last 15 was from full throttle with pto on. Perhaps the tractor ups the voltage needed because of the electric pto?  Think you need a repair manual  and check some specs. Doesn't seem all that bad to me. Maybe the Batt is bad or main cables from it?
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 07, 2014 - 05:32 PM
Here is the schmatic and test points for the 320
Attached File  320_wiring.pdf   167.19KB   35 downloads
Attached File  320_elect_TS.pdf   81.17KB   34 downloads
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 08, 2014 - 11:51 AM
All I know for sure is that when the pto is engaged with the tractor running it causes battery acid to leak from the battery covers
