Mf 7 High/low Range Gearing
10 replies to this topic
#1 propane1 OFFLINE
propane1
  • 13079 Thanks
  • 5844 posts
Posted April 04, 2014 - 03:21 PM
Any body with a MF 7 or 8 geared  have high/low range like mine. Just wondering. Noel
  • A.C.T. said thank you
#2 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted April 04, 2014 - 04:06 PM
If by High/Low you mean a pulley which can be switched around in 15 to 30 minutes, then yes I do.  I have mine on low since I only mow on roughly 3/4 acre of grass.  That gives me the extra low gearing which is nice for trimming around things plus letting my kids drive.  Mostly it moves the gears down about one gear.  3rd low is about the speed of 2nd high, 2nd low is about the speed of 1st high, and 1st is around 1.5 mph as I recall.
  • IamSherwood said thank you
#3 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted April 04, 2014 - 04:35 PM
My 8G has the same setup. I think it has always been in low range since I got it.
#4 propane1 OFFLINE
propane1
  • 13079 Thanks
  • 5844 posts
Posted April 04, 2014 - 07:53 PM
So you put the belt from the big pulley to the small pulley in the middle to get high range to low range. Outside pulley is for the pto.
#5 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted April 04, 2014 - 08:08 PM
I'm not sure you've got exactly the right picture from what you've said.  At the motor of an 8, the pulley only has two grooves, one for driveing the transmission and the other (outer) for driving the PTO.  In between the motor and the transmission, there is a double pulley, with a larger and smaller pulley size.  If the pulley is turned so the large side is belted to the motor, and the small side is belted to the transmission, it reduces the speed of the driven pulley at the transmission.  If the pulley is turned so the small side is belted to the motor and the large side is belted to the transmission, it increases the speed of the driven pulley at the transmission.
#6 propane1 OFFLINE
propane1
  • 13079 Thanks
  • 5844 posts
Posted April 04, 2014 - 09:06 PM
Well with mine I do is move the belt from one pulley groove to the other. All I do is depress the clutch to loosen the belt and move the belt to the middle groove. Takes about ten seconds to change. My pulley on the engine has three pulley grooves, but its all one piece The groove farthest away from the engine is the pto groove. The other two are high low range. Noel
#7 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted April 05, 2014 - 07:04 AM
Can you take a couple of pictures of the setup? That sounds nice and easy.
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted April 05, 2014 - 07:59 AM
Haven't seen that one before, pics would be nice.
#9 propane1 OFFLINE
propane1
  • 13079 Thanks
  • 5844 posts
Posted April 05, 2014 - 11:32 AM
Sorry guys, tractor is in storage at the moment and we are under 2 to 6 feet of snow, but have a picture from the manual, its not a good picture. So in between the drive and pto belts is another belt groove, this where you put the drive belt for low range, just by depressing the clutch and moving the drive belt. Hope this makes sense. Noel
#10 mavtoy OFFLINE
mavtoy
  • 76 Thanks
  • 96 posts
Posted April 06, 2014 - 10:21 AM
Got to say that is a new one on me---- my 7 only has two groove pulley on the motor....I've never seen one with three grooves  but it sounds like it would workout good that way. Thanks for the diagram ( propane1 )
  • propane1 said thank you
#11 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted May 15, 2014 - 06:41 AM
The MF7G that I got recently has the same 3 groove pulley.
I haven't had a chance to try it yet.
  • MH81, HowardsMF155 and Gav694 have said thanks
