Doodlebug/tractor Project
26 replies to this topic
#1 Don Campbell OFFLINE
Don Campbell
  • 1,574 Thanks
  • 1,185 posts
Posted April 04, 2014 - 11:26 AM
I guess I better start a new thread as this project is more involved than I thought it was going to be.
   Todays progress picture shows me after grinding the welds I am applying bodyfiller to the seams.
   I should get the back half of the machine ground and body filler applied this afternoon .
  • Alc, hamman, trowel and 7 others have said thanks
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted April 04, 2014 - 11:34 AM
  • post-7818-0-02865300-1396628763_thumb.jp    great project! thanx for sharing - and the hood has a "Furchenpeiler"! I love those details!
  • hamman, trowel and WNYTractorTinkerer have said thanks
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 04, 2014 - 11:44 AM
The hood has a "what"? :hitting_self_roller:
  • jd.rasentrac and superaben have said thanks
#4 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted April 04, 2014 - 12:05 PM
Wow Don, now I know who to go to when I start my Sears " Hot Rod " project !  Nice work.                                                       Roger.
  • trowel said thank you
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted April 04, 2014 - 01:21 PM
a "furrow direction finder" (notch and bead sighter)
  • trowel and twostep have said thanks
#6 Cvans OFFLINE
  • 6,640 Thanks
  • 6,126 posts
Posted April 04, 2014 - 02:11 PM
Have you ever asked yourself "were do these ideas come from?"
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 04, 2014 - 02:24 PM
I was trying to figure out what a "Furchen" was so's I could try to peal one.
Edited by crittersf1, April 04, 2014 - 02:25 PM.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted April 04, 2014 - 02:45 PM
Sorry if I missed it in a previous thread, but is that a snowblower you are using as a front end?
#9 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted April 04, 2014 - 04:39 PM
Very neat looking "butt buggy".
#10 Don Campbell OFFLINE
Don Campbell
  • 1,574 Thanks
  • 1,185 posts
Posted April 05, 2014 - 06:57 PM
Thanks ,
  Yes it is a walk behind snowblower :bigrofl:
   The gears were shot in the blower so I decided to convert it to a walk behind snowplow. I used it over 15 times plowing my driveway when we got under 4 inches of snow. It worked great.
   Then I had a idea to build a little sulky to hook to it in the summer and take off the blade and just drive it around the yard.
   Todays progress shows it is now green , after a few days I will sand the paint and buff it all out. Then I will paint some yellow stripes on the side .
   Slowly taking shape.
  • EricR and New.Canadian.DB.Owner have said thanks
#11 Don Campbell OFFLINE
Don Campbell
  • 1,574 Thanks
  • 1,185 posts
Posted April 06, 2014 - 04:35 PM
Today I decided to use the tri rib tires i had sitting around for a couple years. I am starting the design for a narrow front swivel wheel system. It will just bolt on and off so I can still put the blade on for plowing snow in the winter.
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted April 06, 2014 - 05:49 PM
How about a self powered rotary mower deck on the front? There's no end to the possible attachments.
#13 Don Campbell OFFLINE
Don Campbell
  • 1,574 Thanks
  • 1,185 posts
Posted April 07, 2014 - 05:38 PM
No front mower, ha,ha.
   Today I worked on the sheet metal on the nose and boxed in one more light . Tomorrow I should get the front done and then start on the last project and that is the hitch
#14 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted April 08, 2014 - 05:31 AM
Did you make that look like a dog face on purpose?
I'd like to see your sheet metal shop.
  • Don Campbell said thank you
#15 Don Campbell OFFLINE
Don Campbell
  • 1,574 Thanks
  • 1,185 posts
Posted April 08, 2014 - 05:05 PM
Ha, ha,
    Todays progress shows the front nose sanded and painted. Once I get the articulating hitch built I may remove the narrow front and just build a cute little normal bumper on front. :smilewink:
   By removing 8 bolts the nose comes off so the snowblade can be mounted back on for snowplowing.
   The sulky won't be used for snowplowing either.
  • sacsr and New.Canadian.DB.Owner have said thanks
