Lawn Sweeper Or Power Broom?
6 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 4155 Thanks
  • 2947 posts
Posted April 03, 2014 - 06:22 PM
Here is my situation,
 the road I live on was recoated with a tar/ gravel combo this fall. As a result the front lawn is covered with 1/4" gravel . I normally hand rake the front yard ( 90' x25' ), to wake up the lawn, but with all the gravel,(at least 10' in) i thought something mechanical would be in order.
options,
rent a power broom for the day @$50 then clean up the mess by hand ( shovel into trailer )
or
buy a lawn sweeper http://www.tractorsu...er-104677299--1
that should pick up the rocks and spruce up the lawn from winter. It could also be used for general cleanup around in the back (1/2 acre) during the summer and fall.
The only thing I'm not sure of is will the sweeper pick up the rocks ? is it strong enough for that? Will it be able to clean up the lawn from the winter or will I need to borrow the neighbors dethacher and run it through the lawn first?
Any suggestions will be appreciated, Tom
#2 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted April 03, 2014 - 06:47 PM
That sweepster will roll 3 inch rocks back on the road if there's some in your yard. My biggest worry when using my Sweepster is gouging the yard through a low spot or sweeping the ground bare if I stop.
  • TomLGT195 said thank you
#3 boyscout862 OFFLINE
  • 15176 Thanks
  • 9995 posts
Posted April 03, 2014 - 07:18 PM
The 1/4" and 3/8" pea stone used in chip sealing doesn't usually cause trouble in lawns because it is so small. The town should have swept it all up a few days after it was put down. It is now your problem. Use an old rotory mower with a bagger that you don't care about. They are usually plentiful at the town dump this time of year because people left gas in them all winter. Set it at a low level and low speed. It will pick up what is loose.  Don't put it back on the road because traffic will just throw it back at you and it can now actually damage the road. You might even get a ticket for putting it on the road.  A bunch of it on the road can cause problems for bicycles too.
Good Luck, Rick
#4 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 03, 2014 - 09:20 PM
Th epull behind sweeper won't pick up the little stuff that ails you right now IMHO.  I think you are looking at the power broom as a best bet.
#5 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted April 03, 2014 - 09:38 PM
A power broom is your best bet.
If you really wanted to make life easy, I rent a skid steer attachment that has a broom that sweeps back into a bucket.  One pass and you can dump the junk right where you want it.  Its a broom and dust pan all in one!
Ben W.
  • MH81, IamSherwood, boyscout862 and 1 other said thanks
#6 Kurtee OFFLINE
Kurtee
  • 673 Thanks
  • 507 posts
Posted April 04, 2014 - 11:43 AM
Take a look at this video. These power brooms work very well to take rocks and gravel out of grass. I wouldn't give mine up.
http://www.youtube.c...h?v=AkAaj10R62M
#7 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1805 posts
Posted April 04, 2014 - 12:15 PM
We use a hand held power broom every spring on the church lawn to put the gravel back into the parking lot after the winter plowing season, works well, if you rent or borrow just be sure to get the shoulder strap that should come with it!!
