Equivalent Carb For Carter Model N
6 replies to this topic
#1 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted April 02, 2014 - 03:16 PM
I have a 12hp Kohler that had a Carter Model N on it originally and I want to know what will fit in it's place. Thanks
#2 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted April 02, 2014 - 03:51 PM
I am in the same boat but mine is on a Cub Original.  What I have found out so far is that you will need the numbers off the carb to find a replacement.
Mine is a 1441 Carter Model N, and so far I am still scratching my head trying to figure out what I can use in its place.
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 02, 2014 - 05:23 PM
The model N doesn't tell you much. Just a name for a bunch of differents carbs. What you need to do is look in the throat of the carb from the choke end. At the top of the venturi there will be some numbers. Will probably read #26 or possibly #30. This picture should help.
  • trowel, boyscout862 and superaben have said thanks
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,316 Thanks
  • 9,786 posts
Posted April 02, 2014 - 05:27 PM
Kohler eventually made their own carb, same as the Carter without the name. Look inside the choke throat for a number. Should be a 26. A 30 is too big. Rarely will you find a 28. Then they went to Walbro. If you get one of those be sure it has the adjustable main jet. Some have a fixed main. And the number system is different than Carter. If the lever on the throttle shaft is different you may be able to adapt it.
  • trowel and boyscout862 have said thanks
#5 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted April 02, 2014 - 10:54 PM
If you have a Kohler K301 12hp with a Carter N series 26 carburetor, I can sell you a reproduction Carter with adjustable jets for $79.  Which is what I would use.  I'd always choose fixed jets if you have a choice.  FWIW and for future reference, I can get a 26 and a 30 reproductions for $79 each.
If you have a Kohler K301 12hp using part number 47 853 22-s, fixed jets, I can sell you a reproduction made by Walbro for $149.  Ouch.
If you have a Kohler K301 12hp using part number 47 853 20-s, fixed jets, I can sell you a reproduction made by Walbro for $149.  Ouch.
If you have a Kohler K301 12hp using part number 47 853 23-s, fixed jets, I can sell you a reproduction for $179.  Double ouch.
Ben W.
#6 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted April 03, 2014 - 08:36 AM
I don't mean to highjack the thread so please forgive me.
Is anyone familiar with the replacement carb that is on a Cub Original??  Mine is a Carter Model N with a number 1441 listed on the top of the carb.  The motor is a Kohler 161S.
#7 VintageIronCollector OFFLINE
  • 1,424 Thanks
  • 1,856 posts
Posted April 03, 2014 - 11:05 AM
My carb says 26 on it
Edited by VintageIronCollector, April 03, 2014 - 11:05 AM.
