Lenovo Pc Down Again!
19 replies to this topic
#1 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 02, 2014 - 10:38 AM
On laptop now.  Came in to check GTT posts, and when I hit a key to "wake" my PC, the fans all came on & won't go off as they normally do right after awakening.  No signal at all to the monitor.   :wallbanging:  :wallbanging:  :wallbanging:  :wallbanging:
  • superspeedex said thank you
#2 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 02, 2014 - 10:47 AM
What happens when if you try and cold reboot?
#3 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 02, 2014 - 11:06 AM
The fans immediately come on, I can hear the HD spinning up, but not a thing to the monitor.  Fan stays running full time.
#4 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted April 02, 2014 - 11:09 AM
Do what I did, buy a new one and then spend all your time cursing and shouting at windows 8  :wallbanging:
  • olcowhand and js5020 have said thanks
#5 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 02, 2014 - 11:16 AM
I found a help spot using the laptop that said unplug my pc, then hold the power button down for 30 seconds to clear all residual power in components.  Well....it worked!  I plugged it back in & I'm on the pc now.  I figure it's on a downhill slide & will do it again, but oh well.  Gotta get back to work now anyway.
  BTW, yesterday I noticed little white lines flashing in & out of the screen for a while.  I'm afraid it's a motherboard thing, as the display card is built in.
  • sacsr said thank you
#6 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 02, 2014 - 02:19 PM
If you have a PCI or PCI express (this being the best) you can by just a card and install it plus the driver (comes with the card) and keep right on trucking.
  • olcowhand said thank you
#7 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 02, 2014 - 02:29 PM
I'll check that out.  But it's the fans running full tilt that makes me wonder.  I just came in & it woke up just fine, fans on slow.
#8 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted April 02, 2014 - 03:33 PM
Sounds like something is getting hotter than it wants to or a temperature sensor isn't reading correct.
Was there not some games consoles and computers that 'Broke' and all they needed was some fresh thermal compound between the processor and heat sink
  • olcowhand and KennyP have said thanks
#9 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 02, 2014 - 05:01 PM
When was the last time you cleaned the inside of the computer?  Dust is a great insulator and one of the main causes for electronic failure.
#10 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 02, 2014 - 05:02 PM
Clean as a new whistle.  When I repaired it just recently, she got an immaculate cleaning.
  • HDWildBill said thank you
#11 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 02, 2014 - 05:11 PM
Then I wouldn't worry to much about it.
#12 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 02, 2014 - 07:40 PM
Make a live ubuntu usb stick. Then at boot up try using the LIVE USB as the drive. If problems go away its the OS. Seen it on my windows laptops.
#13 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 03, 2014 - 09:20 AM
Daniel you have the Zorn disc I sent you which will do the same thing.
#14 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 03, 2014 - 11:00 AM
If it does it again, I will try it.  That would indicate motherboard or OS.  She's been working fine since I did that "power-down" thing.
#15 olcowhand ONLINE
  • 43,138 Thanks
  • 32,005 posts
Posted April 03, 2014 - 11:27 AM
The thin flashing lines are starting up just now.  I figure it's likely the on-board display card.  Might look into ordering one.
