Ploughing Photos In Scotland
26 replies to this topic
#16 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted April 02, 2014 - 09:47 PM
Looks like fun! Thanks for sharing the pictures!
#17 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 02, 2014 - 10:08 PM
Wow. Thanks for the photos. Now I have a goal when I plow the garden.
Any tips and tricks you can share for setting up the plow and plowing? I want my next plowing to look like yours.
#18 daytime dave OFFLINE
  • 4,935 Thanks
  • 6,579 posts
Posted April 02, 2014 - 10:57 PM
Thanks for sharing those great photographs.  I love that huge two wheeler.  It looks like a hand full.
#19 The Fife Plooman ONLINE
The Fife Plooman
  • 1,663 Thanks
  • 308 posts
Posted April 03, 2014 - 07:44 AM
Dear propane1 the part is called the finish and is judged the beginning is called the Feering the next is the throw outs the next throw in then you plough six tops each part is judged  when I am able to I will try to make a video.In the meantime you can look up
www.diamondfarm.com for USA and Canada  Look for a video called
                Vintage Match Ploughing Skills
It applies to vintage tractors used in the UK but the wee tractors follow the same principle  but for competition we only use a single furrow plough
wee is Scottish for small
:love: :reading_the_manual: :watching_you:
  • propane1 said thank you
#20 The Fife Plooman ONLINE
The Fife Plooman
  • 1,663 Thanks
  • 308 posts
Posted April 03, 2014 - 07:55 AM
Coldone starting point
Put the plough on the tractor then set plough on ground.  the tip of the share touches the ground and the heel should touch the ground  it should have a hollow between the two if it does not the share is worn and needs  to be replaced
When I next go to the tractor shed I will take photos and post them
It is easier to show than explain hope this helps
George S :thank_you: :peace:
  • coldone, Cublover and propane1 have said thanks
#21 The Fife Plooman ONLINE
The Fife Plooman
  • 1,663 Thanks
  • 308 posts
Posted April 03, 2014 - 08:10 AM
Sam. Rolloman has an Allan scythe with a plough it looks a beast  it had a bow that went from handle to handle you pressed it down and that raised the plough
They have no reverse so pig to work with.
As a matter of interest I have one with a sawbench have only seen one in Scotland and it is in my tractor shed
  • coldone said thank you
#22 The Fife Plooman ONLINE
The Fife Plooman
  • 1,663 Thanks
  • 308 posts
Posted April 04, 2014 - 01:12 PM
Coldone
Here is a photo of my plough .As I was saying the point of the plough and the heel must touch the ground.
There is  a hollow in the middle which  creates what we call suck this helps to keep the plough in the ground
If you tilt the plough to far forward and point digs in to far This is called dancing on its toes. :beerchug: :big_hug: :bigrofl:  you will never make a nice job this wayPlough suck.JPG
  • coldone and propane1 have said thanks
#23 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 04, 2014 - 07:14 PM
When you set it up on the tractor, do you raise the land side rear tire of the tractor to get the plow to sit level (side to side) before you put it in the ground?
Are depth adjusting wheels used to control the depth of the plow.
#24 The Fife Plooman ONLINE
The Fife Plooman
  • 1,663 Thanks
  • 308 posts
Posted April 05, 2014 - 02:35 AM
Dear coldone
Set the plough on ground with all wheels on the same level.The plough must be level from front to back .when you put the plough in the ground and start. The shape of the mouldboard turns the furrow and presses it against the one before
In competition ploughing speed is not essential   but uniformity is. Try this set the plough in the ground and go fast the plough will throw the soil over and leave broken furrows.Then go slow an allow the plough to turn the furrow you should see a difference
Nice to see your tractor and plow I can then see where you can adjust
Some ploughs have wheels and some do not that come as standard, it is everyone's choice :beer: :beerchug: :big_hug:
Thanks
Edited by The Fife Plooman, April 05, 2014 - 02:37 AM.
#25 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 05, 2014 - 07:08 AM
Here is a video from a few years ago of my wife running the Plow. The plow is a Brinly sleeve hitch type plow that I converted to 3 PTH.
#26 The Fife Plooman ONLINE
The Fife Plooman
  • 1,663 Thanks
  • 308 posts
Posted April 05, 2014 - 10:16 AM
Dear coldone nice video
Your plough would benefit from a disc Coulter or a knife  I will send a picture of what I use if you fitted a land wheel it could help grip
The knife or disc would leave a clean edge to your ploughing
George S
PS what time of year did your plowing take place seems very dry Thanks :love:  Love it
  • Lauber1 said thank you
#27 Cublover OFFLINE
Cublover
  • 93 Thanks
  • 112 posts
Posted April 10, 2014 - 07:18 PM
Wow! Nice straight furoughs. Looks like you fellas are having a good time. I guess we all like playing with our tractors.
