Converting An Onan Twin To A Single Output Coil
2 replies to this topic
#1 DrBob762 OFFLINE
DrBob762
  • 3 Thanks
  • 6 posts
Posted March 31, 2014 - 06:03 AM
my 1975 SS 16 has a bad ignition coil, and i am working on the idea of using one of many single output coils i have on hand. The issue i have is how to effectivly insulate the junction of the spark plug wires into one lead that can be inserted into the high voltage tower on the coil. previous  attempts have shown that standard electrican's tape is not up to the task.(at least in my attempts) Any outher thoughts on how to effectivly insulate this junction will be appricated.....DrBob762.
#2 MH81 OFFLINE
Posted March 31, 2014 - 07:06 AM
Silicon Glue with thick wall heat shrink should work... But I'm afraid you will have intermittent problems.
Electricity will take the path of least resistance, the cylinder NOT under compression would have less resistance at the plug, so the spark will possibly go there instead of the cylinder that should fire. It might work once in a while, but changes in humidity, heat, mix, etc could cause it not to work right or not be consistent.
You would be better off to do two small coils IMHO. I have thought the same about motorcycle coils or something. Someone said that a dual output Harley coil will work, might look into that. They would be two coils in one case, not one coil split.
  • boyscout862, superaben and DrBob762 have said thanks
#3 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted April 28, 2014 - 10:03 AM
2 Bosch super blue coils or look for Harley coils...
