Got Another 214 Today
7 replies to this topic
#1 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted March 30, 2014 - 09:22 PM
got the 1997 JD 214 ( series number 0964XXM) off Craigslist today.  it has been on Craigslist for several days
had to drive around 80 miles one way
we talked and he came down in the price
he did not have the side panels. tires are good
drive it around his yard - ran okay
it came with a 39" and 47" decks
the 47" deck has a few holes in the top
got home and took the 39" deck off to check it out. has not been cleaned for a while
clean it  up and hear it the pile that came off
so I took it all apart - because it need to be fixed and painted
why do people not try care of their things?
I guess some just do not care
and why do they do stupid things like this
they cut the button off the flywheel shield and the broke the end of crank shaft and welded the flywheel back on
I am planning to take the JD 214 all apart and check it all over and fix what needs to be fixed or replaced
some body painted it years ago and now the paint is coming off.  they do not sand it at all before painting it
it is going to be fun working on it
all in all it is in good to above fair shape - so it is going to be good one after I am done with it
  • boyscout862, superspeedex and propane1 have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 30, 2014 - 09:25 PM
Nice find, looks like flywheel nut broke off with the shaft so welded, very common, have repaced cranks because of it.
Same with deck, either don't know or don't care, looking forwards to the restro :thumbs:
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted March 30, 2014 - 09:41 PM
Is that fish supposed to be a cup holder or is that the new way to lube the pulley sheave between the primary and secondary drive belts?
#4 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted March 30, 2014 - 10:35 PM
Cat it is a cup holder
good catch
  • Cat385B said thank you
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 31, 2014 - 05:08 AM
How do you break the end off a crankshaft?
#6 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted March 31, 2014 - 05:15 AM
I didn't know that breaking the crankshaft off at the nut was a problem , does this happen what somebody is trying to remove the nut  ?
#7 Trav1s ONLINE
Trav1s
  • 3,293 Thanks
  • 4,351 posts
Posted March 31, 2014 - 06:38 AM
That steering wheel make it handle better?
#8 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted March 31, 2014 - 09:29 AM
Alc - you can brake the nut off the crank shaft by hitting the nut
first you have to have it loose and hit the nut
that is how it get broke
if they break the end of the crank shaft for the nut they can cut it off and grind it down and drill a hole and tap in the end of the crank shaft and put a bolt it.  then it will hold the flywheel.
Travis - somebody replaced the steering wheel with a chrome with wood.  it is not to bad the steer, but it is going back to a Deere steering wheel
  • Trav1s said thank you
