How Would You Repair This?
25 replies to this topic
#16 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 31, 2014 - 08:00 PM
Thanks for all the help.  When I get it fixed I will post pics ..Thanks again.
#17 MH81 OFFLINE
Posted March 31, 2014 - 09:45 PM
This thread may help you. I did some plastic goofing around last winter and put my dash back together.
http://gardentractor...on/#entry267981
The plastic is whatever you can find. If there is an electronics recycling center, might see if they have a piece of plastic from an old tv back, etc. most of that stuff is ABS and pretty easy to work with.
#18 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 01, 2014 - 06:55 AM
nice link... thanks
found a nice pirce of material to use. Now just got to trim it and epoxy in place. then fill in the divits with JB plastic weld.
#19 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 02, 2014 - 07:51 AM
got the dash fixed for the most part { drying now}   my local hardware store had an epoxy putty,  kinda like play doah.    I  just need to fill in a few more areas and do a little more building, then use my Dremel  and sand it down .  after work I "ll get some pics
  • MH81 and Gabriel have said thanks
#20 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 02, 2014 - 09:19 AM
Glad you got it fixed! Looking forward to the pics!
#21 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 02, 2014 - 06:47 PM
The putty process went well , good thing it set up slow.  it took about an hour for it to set up then dried over nite , now its rock hard. After it set up I sanded down and the touched up with paint .  Here are some pics.
Edited by rdehli, April 02, 2014 - 06:48 PM.
  • olcowhand, MH81, KennyP and 2 others have said thanks
#22 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 02, 2014 - 09:36 PM
Looks good! Did you use putty to fill in the whole gap?
#23 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 03, 2014 - 05:11 AM
Gabriel
I actual found 2 narrow strips of material then used the putty as filler and glue to hold together.
  • Gabriel said thank you
#24 KennyP OFFLINE
  • 38,377 Thanks
  • 45,933 posts
Posted April 03, 2014 - 06:49 AM
What is the name of the putty?
#25 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 03, 2014 - 01:22 PM
Kenny its called PC-11 epoxy putty. here is a link.
http://www.pcepoxy.c...oxies/pc-11.php
bought it at my local hardware store 7.99 for the 2 part tube.
  • limebuzz said thank you
#26 Jmotuzick OFFLINE
Jmotuzick
  • 33 Thanks
  • 47 posts
Posted April 07, 2014 - 02:04 PM
wow very nice work!
seeing as how the new dashes don't have the "international" on them it is a nice save!
