Picked this up yesterday by trading in my Husky 800, I will slowly fix it up and build a loader for it. It runs and drives!
Edited by woopud, March 30, 2014 - 07:26 AM.
Posted March 30, 2014 - 07:24 AM
Wow, Nice machine
Looks to be clean and well taken care of!
Posted March 30, 2014 - 07:59 AM
Even the battery matches! Nice score!
Posted March 30, 2014 - 09:02 AM
nice clean machine.... What's up with the blue sub-frame..? Is that just the pic. ?
Posted March 30, 2014 - 10:24 AM
It looks blue in the pics but it's just the green really faded.
Posted March 30, 2014 - 10:32 AM
Does look like a very clean tractor nice find..
Posted March 31, 2014 - 07:17 PM
Posted April 01, 2014 - 05:37 AM
Can anyone show me some pictures of a hydraulic lift? I'm planning to use the hydraulic cylinder that was used for the mower deck lift. Thanks!
Disregard this question, it will be more beneficial for me to use those existing hydraulics for power steering since it will get a front end loader. Will the single action cylinder work for that? Again I like to see some pictures, this time of a power steering set up.
Posted May 04, 2014 - 12:16 PM
Posted May 04, 2014 - 06:26 PM
I would use what the manual tells you to.
SAE30 or 10W-30 would be good for the engine oil and for the tranny SAE20 ( Type SE,SC,SD) Is recommended.
I would also change your Bolens filter 1726450 while your at it.
Posted May 04, 2014 - 07:03 PM
Posted May 04, 2014 - 07:06 PM
Could I get the filter at a auto parts store? Don't really see SAE 20 oil anywhere either.
I've seen it at some stores around here so I think its still out there. Hopefully someone chimes in who has one of these Hydrostatics.
I have the good USA made hydro filters in stock if you need one.
Posted November 23, 2014 - 02:19 PM
What am I missing? Where the throttle and choke cables go through the "firewall" should there be some kind of bracket that holds the cables?
There is a choke bracket missing that mounts right above the carb on the engine shaped somewhat like this.
---|___
And then the clamping hardware that mounts on the bracket.
