Followed Home By A John Deere 400
21 replies to this topic
#1 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted March 29, 2014 - 07:46 PM
Darn it anyway, another tractor has followed me home. This time it was a JD 400 with lots of problems but the free for the hauling part hooked me. As you can see in the pics it's missing a few vital parts like wheels and a steering wheel but there are still loads of goodies to be had. I was told the engine is blown due to operation without oil but that will take a little testing to verify. It turns over freely but sounds like it may have no compression. We will see. At least I know that it can easily be moved about by a Case 646.
Edited by Case-Closed, March 29, 2014 - 07:50 PM.
  • Alc, boyscout862, jd.rasentrac and 2 others have said thanks
#2 propane1 ONLINE
propane1
  • 8,729 Thanks
  • 4,134 posts
Posted March 29, 2014 - 07:49 PM
Lucky you. Always wanted a 400. Noel
  • Case-Closed said thank you
#3 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted March 29, 2014 - 07:52 PM
I may not be so lucky, it's likely just more yard art.
Edited by Case-Closed, March 29, 2014 - 09:53 PM.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 29, 2014 - 07:58 PM
That 400 looks to be in great shape other than the missing parts and the engine issue. There's still a lot of good parts on it.
  • jd.rasentrac and Case-Closed have said thanks
#5 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted March 29, 2014 - 08:06 PM
Hey that little Case is pretty strong that's no lightweight you have there
  • superaben and Case-Closed have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 29, 2014 - 08:22 PM
I was thinking the same way.
Ben W.
#7 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,693 posts
Posted March 29, 2014 - 08:27 PM
:iagree:
#8 propane1 ONLINE
propane1
  • 8,729 Thanks
  • 4,134 posts
Posted March 29, 2014 - 08:59 PM
I was going to say the case was very strong to lift the 400 , but I screwed up on posting. Any way I got it on. Noel
#9 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted March 29, 2014 - 09:52 PM
Mr. Case 646 has had some modifications over the past year, I picked an airport runway concrete saw out of the back of a truck a while back and it weighed in at 643 lbs. I guess the 500# weight box does make a difference.
Edited by Case-Closed, March 29, 2014 - 10:05 PM.
  • jd.rasentrac, SamMC and Oldford have said thanks
#10 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted March 30, 2014 - 05:32 AM
yep, many parts are absence, but this 400 may "help an other 400"
#11 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted March 30, 2014 - 08:36 AM
I will gladly trade the 400 for a Case 600 series basket case as parts are parts.
#12 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted April 02, 2014 - 11:09 AM
Looks to me like a great project for a diesel repower if that engine is toast.  I may have some front wheels that will fit it.  Rear Wheels are odd-ball pattern, but you could maybe build an adapter so the standard 12" diam. 5 on 4.5" pattern would mount up.
Does it have Power Steering???
Smitty
  • BowlBuilder and Case-Closed have said thanks
#13 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted April 02, 2014 - 09:58 PM
Hey Smitty! The answer to your question is yes. There is power steering on this critter and I have considered robbing it off and putting it on my 646. In the end though I think I prefer to use the whole darn thing for trading stock for more Case related goodies. I could use a good running engine for an old Case 220 but am open to all sorts of junk.
  • Utah Smitty said thank you
#14 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted April 03, 2014 - 03:24 PM
I'm just trying to think what Case parts I have l left.  I sold my machines other than the 444 I picked up in Arco, ID last year... still have some odds and ends--pump mount for Onan Engine, etc. ...  oh well!!!!
Smitty
#15 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted April 06, 2014 - 09:15 PM
Well I had some free time today so I took a look at the JD 400 that followed me home last week. When the key was turned it sounded like something had been disconnected and it most definately had. Dont know the circumstances of this tractors last days running but I think stupidity was in on the party. The Kohler 20 HP is totally destroyed in ways I have never seen. The pistons were smashed to bits as were the connecting rods. There is a rather large hole near the filter and the bottom of the oil pan is loaded with broken parts. The crank shaft is in one piece but one journal has major scoring  and a gouge in it like I have never seen. That leaves us with the camshaft that somehow got broken into three pieces. It is really tough to tell what failed first but I suspect it made quite a noise.
Edited by Case-Closed, April 06, 2014 - 09:45 PM.
  • Rock farmer said thank you
