Kohler K482
21 replies to this topic
#16 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted March 30, 2014 - 11:20 AM
Ok thanks, maybe I'll just start with that... Is there a special way to get them out of the housing when the hubs are gone ?
Sorry about all the questions but it seems like I'm the only Bolens freak in Sweden :(
Just a flat screwdriver or something with a little hook will work.   No need for any sorrys were here to help I think there is one or two other guys out your way with bolens.
#17 boyscout862 OFFLINE
  • 15260 Thanks
  • 10023 posts
Posted March 30, 2014 - 11:36 AM
I've seen several nice Bolens posted from Sweden. Read the manual about the axlel. Protect the new seals with something on the axle as you slide it on. Someone did a thread about this with a bunch of good pictures. Good Luck, Rick
This may include the trany:   http://gardentractor...service-manual/
Edited by boyscout862, March 30, 2014 - 11:46 AM.
#18 Djupliden22 OFFLINE
Djupliden22
  • 9 Thanks
  • 19 posts
Posted March 30, 2014 - 03:30 PM
Setback... Dont know the name for them but the "slide" bearing for both camshaft and crank were destroyed... Are they still availible ??
Regards
#19 Djupliden22 OFFLINE
Djupliden22
  • 9 Thanks
  • 19 posts
Posted March 31, 2014 - 02:23 PM
Hi everyone!
Someone told me I could get better prices through GTT. Is that so ?
This is what I want for my Kohler and Eaton 12. Have found some of them on Ebay but often different sellers so the shipping to Sweden is too costly to get all parts.
I know it is a bit much to ask for but if anyone here could help me right away with a package deal or direct me to someone who can I would be grateful.
2 pcs 235008-S Intake Valve
2 pcs 235838-S Exhaust Valve
1 pcs 4803006-S Bearing Crankshaft
1 pcs 277039-S Rear Cam Bearing
1 pcs ...... FrontCam bushing (didn´t find the part number) for that
1 pcs 2503206-S Oil seal
1 pcs 277375-S Coil
2 pcs 235287-S Piston Rings
4 pcs 235007-S Valve Guides
Eaton 12
          Bolens Part.nr:        Eaton Part.nr:
2 pcs    1720315                ET-94275            Needle Bearing (if possible to change from the outside)
2 pcs    1719877                ET-94276            Axle Seal
Kind Regards
Jörgen
#20 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted March 31, 2014 - 05:16 PM
Try one of these guys.
http://gardentractor...arden-tractors/
http://gardentractor...-tractor-parts/
http://gardentractor...aths-equipment/
http://gardentractor...parts-supplies/
  • Bolens 1000 and blackjackjakexxix have said thanks
#21 drbish OFFLINE
drbish
    Collecter
  • 1627 Thanks
  • 1412 posts
Posted April 01, 2014 - 05:15 PM
Could you give me the  spec number for your kohler,most of the 482 kohlers show a 277065 rear oil seal when i search your 2503206s  number it also shows rear oil seal,and by the way it was me that told you,better prices here,as of right now all i have instockare the ones i pm you about and a 277065s rear oil seal.Evidently you have a different crankshaft size than the one this seal fits.Shipping is like 70.00 dollars from what i have found so you are right get every thing you need in one shipment.Give me until Friday evening and i will see what i can come up with.
#22 Djupliden22 OFFLINE
Djupliden22
  • 9 Thanks
  • 19 posts
Posted April 05, 2014 - 08:56 AM
Hi again!
All I can find on the engine is that the model is a 1886-4 Bolens... Will this help ?
Also, Can anyone tell me if it is normal on an Eaton 12 tranny to be able to push both wheel axles in and out for about 4-5 mm. If not, what could the cause of the problem be ?
I can´t "flex" the axles in any other directio so the bearings seem ok.
Regards
