What Do I Have?
transmission for?????
14 replies to this topic
#1 Petenpole ONLINE
Petenpole
  • 154 Thanks
  • 157 posts
Posted March 28, 2014 - 09:49 AM
Ok friends I need some help identifying what I bought.
It is a transmission with bell housing, pressure plate, disc, throwout bearing. I do not have the hub  that goes on the crankshaft and bolts to the plate( in a car it would be the flywheel) . I do have the plate  that the disc rides against just not the hub. Small work on the lathe.
The transmission side cover was loose so i pulled the 4 bolts and found one gear with a broken tooth.
Depending on what this transmission was used for and on will determine if its another dream project and a rebuild or not.
Any help identifying what I have purchased?
Thanks again for any help out there.
  • hamman said thank you
#2 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted March 28, 2014 - 10:35 AM
Looks like from and old(30s - 50s) small car. The split case is sort of familiar, maybe British. You've got my curiosity up. Good Luck, Rick
#3 Petenpole ONLINE
Petenpole
  • 154 Thanks
  • 157 posts
Posted March 28, 2014 - 11:05 AM
Rick good thought but here is what is perplexing to me.  The large disc under the pressure plate is what the clutch disc rides against.
It has an approx 1 inch bore and has a bearing in one end that would appear to be in place of the old pilot bearing on a flywheel. That same disc/plate has 3 holes drilled in it (right around the hub bore) that would in my best guess bolt to a hub that is slid onto a crankshaft.
The bell housing has  4 holes that match the transmission, and then on the other end it has 4 holes that are not in a Square. The 2 bottom holes are wider in distance (center to center) than the uppers.
My first thought was this was a transmission that bolted up to an old model 23 B&S but at this point I am not making any more guesses. I need the expertise of friends and those far wiser than myself.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 28, 2014 - 04:04 PM
That is nothing like i have ever seen for the Briggs but not saying it could be, the off center holes on the back of the gearbox could be for a drop box (chaincase), tractor or boat ?
#5 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted March 28, 2014 - 04:25 PM
This bears watching!
  • Petenpole said thank you
#6 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted March 28, 2014 - 05:18 PM
The bell housing looks the very much like the one that  is attached to the Onan engine in my R/T tractor.
My engine and transmission setup is from 1966.
Mine has a T-96 transmission ( the same transmission used in the older Jeeps ).
I don't know what your transmission is but it isn't a T-96.
I realize that this information doesn't help you a lot, it's just an observation.
Edited by jdcrawler, March 28, 2014 - 05:22 PM.
#7 glgrumpy ONLINE
  • 8,605 Thanks
  • 7,913 posts
Posted March 28, 2014 - 05:28 PM
Very similar to Power King Economy system. Looks like same clutch pressure plate. Big bellhousing  almost similar in front where it bolted up to the Kohler and Briggs engines, some having a big ring/edge to fit into center space and keep aligned. PK's used a T92 trans, again similar looking if that is the trans as mentioned above.  Think Borg Warner parts is what makes it all familiar here.
#8 Petenpole ONLINE
Petenpole
  • 154 Thanks
  • 157 posts
Posted March 28, 2014 - 07:37 PM
The bell housing will match up to an old 12hp cast iron Briggs I have in the shed. Where do I find a Borg Warner name on trans if it is a BW?
#9 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted March 28, 2014 - 10:40 PM
I will have to look but that reminds me of the transmission and bell housing that are in an old Cushman truckster.
#10 Cushman fixer ONLINE
Cushman fixer
  • 5 Thanks
  • 6 posts
Posted January 13, 2018 - 04:04 PM
Hey y’all, i know this thread is long gone, but i would love to know the ending of this one.
I get a lot of these transmissions off the Truckster
They used to use the T96, but then went to this unit for the PTO I assume.
Any luck with identifying the make/model? Haven’t been able to rebuild due to lack of info. I believe that the PTO’s were made by Chelsea
Thanks, Spencer
#11 Cushman fixer ONLINE
Cushman fixer
  • 5 Thanks
  • 6 posts
Posted January 15, 2018 - 05:36 PM
Rise o zombie thread!
Sure hope somebody figured out what this trans is
#12 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted January 16, 2018 - 10:26 AM
I just did some researching on the internet on this and the only thing that I can find is that this is the aluminum transmission used in the Cushman Trucksters in the 80's.
I didn't find anything that told me who manufactured them for Cushman.
There are some complete transmissions and parts for sale on ebay right now.
Edited by jdcrawler, January 16, 2018 - 10:26 AM.
  • Cushman fixer said thank you
#13 Cushman fixer ONLINE
Cushman fixer
  • 5 Thanks
  • 6 posts
Posted January 16, 2018 - 10:32 AM
Thanks jdcrawler, that’s been my problem
When you crack it open, it looks like a knock off of a T96. Lots of little similarities, especially with the shifters and interlock.
I know they’re out there, I’d just love to be able to rebuild one
Thanks again
  • jdcrawler said thank you
#14 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted January 16, 2018 - 08:00 PM
The original poster hasn't been on since July 2016. The only trans I ever worked on that split like this one was a Puegot (sp?) trans on a jeep Wrangler. Late 80's?
#15 Cushman fixer ONLINE
Cushman fixer
  • 5 Thanks
  • 6 posts
Posted January 16, 2018 - 08:27 PM
Thanks Doug, that would be the right time frame.
I’ll check into it further
Spencer
