Ff Tail Lights Maybe?
29 replies to this topic
#1 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted March 26, 2014 - 12:26 PM
I have 4 of these lights, one is an LED. I am thinking of using them in place of the reflective decals on the FF's as I am not sure if I can find replacements for them. These are made by Peterson Mfg. (PM). What do you all think?
  • Texas Deere and Horse, hamman, A.C.T. and 1 other said thanks
  • 14,811 Thanks
  • 15,499 posts
Posted March 26, 2014 - 01:31 PM
Kenny, Stop by any truck stop and they should have replacement lights that are the same.
  • Bill 76 said thank you
#3 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted March 26, 2014 - 01:39 PM
That's one reason I thought of using these, readily available! I'll have to make a large hole (2") for them to fit into.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 26, 2014 - 02:45 PM
Kenny have a look at what's available in LED trailer lights. There are some larger ones that might look better and also be more visible. It's always a good idea to add lighting to the back of a GT IMO. I replaced the reflectors with same sized led lights on the 314. Anything that improves your visibility at night is a good thing.
#5 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted March 26, 2014 - 02:46 PM
Every truck stop and parts stores around here sells them,no problem geting new ones--and they will last forever and can handle the shaking and vibration.
Peterson makes good stuff.
And if you can buy brakets with the hole punched in them to mount them cuz it's an odd size hole and I have not been able to find a hole saw that size.
  • Texas Deere and Horse and KennyP have said thanks
#6 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted March 26, 2014 - 03:32 PM
I don't get out much after dark, so that's not an issue. I think the one I have with 3 LED's in it will do quite nicely. Just have to get 3 more. As far as the holes, I'll get them figured out.
#7 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 26, 2014 - 04:25 PM
And, you can easliy add a flasher to them to get more attention.
click for video..........
Edited by KC9KAS, March 26, 2014 - 04:25 PM.
  • IamSherwood, KennyP, A.C.T. and 2 others have said thanks
#8 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted March 26, 2014 - 04:35 PM
The right LED can be functional but really add to the look.  Open your wallet Kenny LOL!
#9 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted March 26, 2014 - 06:03 PM
What kind of flasher did you use on that KC?
#10 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 26, 2014 - 06:14 PM
It was a special alternating flasher designed for LED lights. Actually purchased from a guy at a motorcycle ralley.$20 or $25 bucks.
Starlight LED's.
  • KennyP and Walkinman1 have said thanks
#11 Sawdust ONLINE
Sawdust
  • 5,657 Thanks
  • 3,370 posts
Posted March 26, 2014 - 06:50 PM
Sorry Kenny I have to go with the majority on this one. I like using what I have too but sometimes buying something looks better. You need something similar to what you have to keep that stylish look of that rear fender area  :D
#12 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,499 posts
Posted March 27, 2014 - 10:11 PM
Kenny, here is what my NAPA keeps on the shelf.
2" Sealed LED
2 1/2" Sealed LED
I will check tomorrow morning in rectangular ones.
#13 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted March 28, 2014 - 07:09 AM
The rectangle ones would have to be small as the fender pan angles up toward the corners. That's why I was thinking round. And the rubber for the 2.5" ones may be to wide overall to fit in the area. The 2" rounds will just fit straight above the center of the tires.
#14 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted March 28, 2014 - 08:16 AM
I had to replace the LED tailight on our church trailer, it was the oval one, almost rectangular one. We had top buy the whole assembly as they are sealed and it was only $6-7 per light at local trailer shop. I think with the rubber mounting gasket it was $10-12.
They maybe 3" long and had turn signals in them which you could always wire around.
#15 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted March 28, 2014 - 08:25 AM
Got a pic or a # on those?
