Cadet 109
5 replies to this topic
#1 Phil Be me OFFLINE
Phil Be me
  • 1 Thanks
  • 1 posts
Posted March 26, 2014 - 07:47 AM
Just bought a decent 109 with tiller and mower. It has been sitting for two years. Got it running yesterday, purrs like a kitten. Problem is when in forward or reverse it won't move. Everything looks to be connected and correct..any ideas ?
#2 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted March 26, 2014 - 08:31 AM
:wave: Welcome to the forum! The valves in the hydro may have stuck down. Does it roll easily?
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 26, 2014 - 10:21 AM
Welcome to GTTalk. Congrats on the new cub. There is probably a travel valve on those somewhere to protect the transmission from damage if you need to push or tow the tractor. That may still be in the travel position. I have never owned one so I can't help with locating the valve.
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 26, 2014 - 11:12 AM
  :ditto:  Also check the roll pins in the driveshaft. They might have broken or come out. You can check the valves and the rear roll pin by pulling the tunnel cover off.
Edited by LTD, March 26, 2014 - 11:12 AM.
#5 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 27, 2014 - 07:22 AM
yup check the roll pins.  also check the rear end oil too.
#6 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted March 27, 2014 - 07:56 PM
As mentioned, check the control valves. Pull the tunnel cover and start the tractor and see if they pop up, sometimes they get stuck.
Also have you checked the fluid? Sounds like a dumb question, but sometimes it's easy to forget the simple things. Does it try to move at all? Make any noises?
