Attachments Using A Gts Rear Pto?
40 replies to this topic
#16 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted March 26, 2014 - 10:02 AM
Never seen one for a GT but i could imagen one converted to 3 point.
  • gtcsreg said thank you
#17 olcowhand ONLINE
  • 36,196 Thanks
  • 29,976 posts
Posted March 26, 2014 - 10:23 AM
Most of the rear pto pieces posted in reply have no connection to what I feel is the OP's true point of what is available to HIS Massey shaft rear pto.  Many of what have been posted could however be adapted to use with shaft pto.
  • Bolens 1000, trowel, gtcsreg and 1 other said thanks
#18 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted March 26, 2014 - 10:25 AM
Your right, figured throwing out some ideas could help, don't know MF that well.
#19 olcowhand ONLINE
  • 36,196 Thanks
  • 29,976 posts
Posted March 26, 2014 - 10:39 AM
Not meaning to point to anyone....just wanting to point that out.  I'm sure the OP appreciates all replies just as I do.  :thumbs:
  • trowel and gtcsreg have said thanks
#20 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted March 26, 2014 - 10:44 AM
I know, no probs.
#21 gtcsreg ONLINE
gtcsreg
  • 1,701 Thanks
  • 1,681 posts
Posted March 26, 2014 - 01:22 PM
Yes, trying to determine whether to swap the 3 point over to the restored tractor and not worry about the locked up PTO.  If I swap the 3 point over then I would just use the unrestored one for little projects around the house and maybe never pretty it up.  OR, the more expensive and time consuming effort to restore the "new to me" one.  It's a hard decision to make.
Reg
Edited by gtcsreg, March 26, 2014 - 01:23 PM.
#22 coldone OFFLINE
coldone
  • 1,634 Thanks
  • 1,671 posts
Posted March 26, 2014 - 04:58 PM
Reg
I am kinda in the same boat. I have 3 Gts that have rear PTOs, only one working rear PTO. So far I have not hade the chance tobuy any attachment that will run off of one. There have been maybe 3 tillers inthe past few years on CL that I could have used but  they were too expensive for me. Other than that, I have not seen anything for sale that I could use the rear PTO for.
Now I do have some future plans on trying to make or adapt some stuff for use on them. Untill I have time to work on those projects I will not worry about the rear PTOs. SO swap over the 3PTH and dont worry about the PTO.
#23 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted March 26, 2014 - 05:15 PM
IMO you can do more with attachments with the three point if built right or the right set up found.
#24 BowlBuilder OFFLINE
BowlBuilder
  • 448 Thanks
  • 430 posts
Posted March 30, 2014 - 04:04 AM
I guess I'm guilty of posting something completely useless to the person who started this post.  Sorry about that.   Thank you for pointing that out, oldcowhand.  :thumbs:
#25 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted March 30, 2014 - 04:37 AM
I know about finish mowers, bush hogs, and tillers.  Are there other attachments that use a rear PTO on GTs?
Where in the OP's post was His Massey said?   "Are there other attachments that use a rear PTO on GTs?" Does GT stand for Massey? Just saying....   I'm sorry I don't know all the meanings of PTO,GT,LT,rear shaft PTO, ect... I'll think very hard before I add my thoughts on anything. Maybe I should check with someone first to see if it's OK to add to any post that I didn't start? Now who would that be????  Or should I just read the posts and not add to them?
Edited by Fluid, March 30, 2014 - 04:57 AM.
#26 gtcsreg OFFLINE
gtcsreg
  • 1,701 Thanks
  • 1,681 posts
Posted March 30, 2014 - 07:58 AM
ALL of the posts were appreciated.  I've modified stuff before so all stuff was considered.  I should have said Massey/Snapper but this post is in that section.  In my opinion, all posts are good ones except mean ones!
Thanks to all,
Reg
#27 olcowhand ONLINE
  • 36,196 Thanks
  • 29,976 posts
Posted March 30, 2014 - 08:11 AM
It is very obvious you took me the wrong way.I was simply trying to point out he was likely interested in what was for his tractor's rear pto, which is a Massey, and his post in the Massey section, not the general garden tractor area.  Reg has had other posts about his tractor involving his inoperable rear pto.
 And yes, many Massey models do use belt drive rear implements, but the belts are driven off front or mid pto's.
 I am sorry if I offended anyone, which is never my intent.  Being I have read his other posts, I was simply trying to help center the focus where I felt it was needed to help him the most.  I am not here to offend or jerk people's chains.
  • OldBuzzard, BowlBuilder and Juneau have said thanks
#28 OldBuzzard ONLINE
OldBuzzard
  • 6,573 Thanks
  • 4,651 posts
Posted March 30, 2014 - 11:09 AM
It is very obvious you took me the wrong way.I was simply trying to point out he was likely interested in what was for his tractor's rear pto, which is a Massey, and his post in the Massey section, not the general garden tractor area. ...
Was this originally in the Massy Forum?
Just wondering cause it's in the General Garden Tractor Forum now.
Maybe that's the cause of some confusion?
Edited by OldBuzzard, March 30, 2014 - 11:13 AM.
#29 olcowhand OFFLINE
  • 36,196 Thanks
  • 29,976 posts
Posted March 30, 2014 - 11:32 AM
I sure thought it was in the MF forum. Maybe it was moved, but I'm not sure.  Oh well, may just be me confused.  :(
#30 OldBuzzard ONLINE
OldBuzzard
  • 6,573 Thanks
  • 4,651 posts
Posted March 30, 2014 - 01:09 PM
Dang Ol ... you're to young to be having "Senior Moments"
Now I on the other hand, have been known to have "Senior Days" :rolling:
