8Hp Arc Welding Unit - Value?
8 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted March 23, 2014 - 07:54 PM
I have had an ad on Kijiji for a 4 hp Wisconsin ABN.  Today I got a reply from a guy with an 8.2 hp AEN (1950 build date).  It is on a stick welder his father had on the farm.  I don't need the welder and the engine is too big for my needs, but who can say no to a good deal?  Any idea what a fair price might be for the unit, assuming it runs, is in average condition, and it is an hour away?
I know. I know.  Value depends on need.  Neither I nor the buyer need it. :-)
  • trowel and boyscout862 have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 23, 2014 - 08:05 PM
Depends on the welder, condition, age etc.... gas powered welders are buzz box generators, usually always priced the same unless welding assy a with, name brand, collectibility, then a little more.
That's and old girl, would be in the price range of roughly old school 3000 watts AC generator.
I would go cheap, $ 50 to $ 100, remember you don't need a welder and that has the tapor and tapped crankshaft.
  • boyscout862, New.Canadian.DB.Owner and superaben have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 23, 2014 - 08:13 PM
:iagree:
Ben W.
  • boyscout862 and New.Canadian.DB.Owner have said thanks
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted March 23, 2014 - 09:32 PM
I'd do some research to find out if the crankshaft is tapered for the welder connection.
Mike
#5 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted March 23, 2014 - 09:51 PM
:iagree: about the tapered shaft.
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 23, 2014 - 09:59 PM
#7 boyscout862 ONLINE
  • 12,849 Thanks
  • 9,171 posts
Posted March 24, 2014 - 05:12 AM
A gasoline powered welder that doubles as a generator is often handy. I have two. Mice love to get into the generator part and chew the wiring. Good Luck, Rick
  • trowel and New.Canadian.DB.Owner have said thanks
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 24, 2014 - 05:17 AM
Some of the older generators had a 2 bearing head and a coupler rather than the tapered shaft connection. It's worth checking. If the welder can also supply 120volts it's a mighty handy thing to have.
  • trowel, boyscout862 and New.Canadian.DB.Owner have said thanks
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 24, 2014 - 06:31 AM
That reminds me, i doubt it but i did come across a little genny that the rotor windings were keyed onto a 12 inch or so straight shaft, forget the maker or model but after the rotor was removed it looked so odd having a two mile long pto.
 Ironiclly the keyway ran the whole length of the shaft so a cutting disk reduced it to normal size.
Edited by trowel, March 24, 2014 - 06:33 AM.
  • JDBrian and New.Canadian.DB.Owner have said thanks
