MF 7/8 Wheel weight bolts
5 replies to this topic
#1 NYMalloys OFFLINE
NYMalloys
  • 29 Thanks
  • 43 posts
Posted January 14, 2011 - 09:24 PM
I have wheel weights for an MF 7, which I've always mounted with lengths of threaded rod into the hub, lug nuts to hold the wheel, then the weight and then lock washers and nuts. Recently an old massey dealer, told me that a special male/female lug bolt was used to hold the wheel to the hub, then the weight and then the original wheel lug bolt was threaded in. Sure enough, I found what he was describing in the parts book, but it's long been discontinued. Would anyone have a picture of the lug bolt he described? Thanks.
#2 jj69chev OFFLINE
jj69chev
  • 24 Thanks
  • 150 posts
Posted January 16, 2011 - 07:49 PM
I have what your looking for I think, I'll run to the shop and snap a pic for you
#3 jj69chev OFFLINE
jj69chev
  • 24 Thanks
  • 150 posts
Posted January 16, 2011 - 08:14 PM
IMG_20110116_190754.jpg Here's a couple pics first the rims on my MF8 then the weight nut/bolt
  • NYMalloys said thank you
#4 NYMalloys OFFLINE
NYMalloys
  • 29 Thanks
  • 43 posts
Posted January 17, 2011 - 09:24 AM
Thanks for the pictures. These look like you can keep them in when you take off the weights in spring. I think I could fabricate something like that out of threaded rod couplings (if I can get them in grade 5 or better steel), I would need to turn the side facing the wheel hub to bevel the end.
#5 jj69chev OFFLINE
jj69chev
  • 24 Thanks
  • 150 posts
Posted January 17, 2011 - 11:23 AM
Can definitely keep them in, i just took the weights of for the resto I'm starting, otherwise they have always been on the tractor
#6 tinner OFFLINE
tinner
  • 504 Thanks
  • 1561 posts
Posted January 17, 2011 - 12:36 PM
If you don't have a way to turn down the ends of the couplings, you might consider TIG welding lug bolts to the couplings.
