Anyone Else That Needs To Add Transaxle Grease Easy.
9 replies to this topic
#1 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted March 22, 2014 - 07:03 PM
RED, the 917.254450 has serious axle leaks, and the rims are frozen to the axle so a proper fix is not possible. So, every year now for pre-mowing maintenance I pull the pan and add 2 funnels of "00" grease. This goes with an oil change, steering lube, and air filters.
  • hamman, Traill95 and boyscout862 have said thanks
#2 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted March 22, 2014 - 07:59 PM
The only time I succeeded getting the wheel off one of those axles required disassembling the transaxle, pulling the axle and wheel out, and putting it on a press. Good Luck, Rick
#3 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted March 22, 2014 - 08:21 PM
These rims are NOT coming off, hence my method of adding grease to keep the transaxle working fine. Just finishing up with the second funnel full (5 hours) to get two in, but this will last till next year.
#4 MH81 OFFLINE
Posted March 22, 2014 - 08:33 PM
Ryan's greens mower is pumped full of regular grease.
  • larrybl said thank you
#5 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted March 22, 2014 - 08:37 PM
I would be doing too that except I was given 5 gallons of "00" Dura Lith grease.
#6 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted March 22, 2014 - 09:07 PM
I'm not sure if regular grease should be used in a trans. like yours. Maybe yours is different than some I'm thinking of.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 22, 2014 - 10:27 PM
Free is good.  :thumbs:
I'll tell you, though.  I'd rather watch grass grow that watch 00 grease pour into a transmission.
Ben W.
  • HDWildBill and TX_Dj have said thanks
#8 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted March 22, 2014 - 11:01 PM
It took around 5 hours to get two funnel full into the tranny. More to the point, this is RED's annual service before a long Summer of mowing 2.5 acres.  I also am doing this service in my new shop which does take some getting used too.
  • superaben said thank you
#9 TX_Dj OFFLINE
TX_Dj
  • 141 Thanks
  • 84 posts
Posted March 23, 2014 - 12:46 AM
Does that trans not have a PRV?  I find on my earlier tractors, filling goes a bit quicker when I pull the PRV so that the air has someplace to go.
Then again, I'm not pouring 00 into it. :D
#10 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted March 23, 2014 - 12:57 PM
Ii doesn't have a Pressure Release, only access is the plastic plug, this is a 6 speed transaxle.
  • TX_Dj said thank you
