Grass On Top Of Deck ?
17 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,726 Thanks
  • 4,132 posts
Posted March 22, 2014 - 10:28 AM
http://gardentractor...machine/page-2#
Not sure if this will work for a picture, any way most of my decks always have grass on the top of them. Anybody else notice this. Why dose it happen and how could it be fixed. The grass is suppose to go out the chute, not on top of the mower , or is that just the way it is. Just a crazy question, Noel
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted March 22, 2014 - 10:39 AM
Grass, leaves or what ever you are cutting goes everywhere.  It is amazing how much dirt, grass and leaves I clean out from under these mowers.  Add a little water to the mix and have a pretty hard mess to break up.  I usually take the tractor to the shop and use shop air to clean it up before putting it  away.
  • boyscout862, superaben and SamMC have said thanks
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted March 22, 2014 - 10:41 AM
:ditto:  I use a leave blower to clean off most of it.
Edited by DH1, March 22, 2014 - 11:20 AM.
  • HDWildBill and SamMC have said thanks
#4 SamMC OFFLINE
SamMC
  • 209 Thanks
  • 176 posts
Posted March 22, 2014 - 11:17 AM
Great ideas guys, thanks!
#5 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted March 22, 2014 - 11:24 AM
I don't think there is a way to keep that stuff off other than not using it!
  • HDWildBill and propane1 have said thanks
#6 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted March 22, 2014 - 01:08 PM
I use a leave blower to clean off most of it also. Seems like the easiest way. Sometimes I take a battery impact and zip the belt guards off and really give it a going over with the leaf blower. :dancingbanana:
#7 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 22, 2014 - 01:39 PM
Try servicing a lawnmower with a broken belt and that mess.  :wallbanging:
The only way to keep it out it is to create a belt cover over the whole shebang, a la Grasshopper ZT mowers.  That creates a smooth surface for the air to blow off as you move, not a forest of guides, spindles, pulleys, and belts.  There will still be dust and junk in behind it, though.
Ben W.
  • superiorpower and HDWildBill have said thanks
#8 propane1 ONLINE
propane1
  • 8,726 Thanks
  • 4,132 posts
Posted March 22, 2014 - 02:07 PM
Never thought of a leaf blower. I like the idea of not using it. Noel
#9 superiorpower OFFLINE
superiorpower
  • 41 Thanks
  • 67 posts
Posted March 22, 2014 - 02:08 PM
Ben W.
And the problem with this setup is the moisture that accumulate behind it but can't dry out. I personally prefer the types that just have belt guards so you can blow it out. I use a leaf blower like some others mentioned. I try to do this after each mowing. Shop air works too. If the grass was damp enough to stick to the top, you might have to use a water hose, which is not as effective since it makes the grass stick to everything. But if the grass is already stuck to the deck you have to do something. Bottom line. Clean it off. Otherwise you will have a rusty deck in a few years.
  • superaben said thank you
#10 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted March 22, 2014 - 02:27 PM
I use shop air with one of those cheap blow guns. Removed the factory nozzle and replaced it with a 18-24 inch piece of brake line. Long small line really reaches in there and directs air to those hard to reach spots. A lot lighter than the big blower and able to get under the machine.
Not a fan of the solid belt covers, they seam to trap grass and are impossible to remove without removing the deck.
  • propane1 said thank you
#11 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,927 Thanks
  • 5,976 posts
Posted March 22, 2014 - 02:42 PM
Air compressor or a good old fashioned corn broom.
#12 HDWildBill OFFLINE
  • 8,975 Thanks
Posted March 22, 2014 - 02:43 PM
Try servicing a lawnmower with a broken belt and that mess:wallbanging:
Ben W.
I do all the time.  I have a JD 320 getting a new motor and it was a mess under there getting to the drive belt.  What a mess!
#13 classic OFFLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted March 22, 2014 - 05:16 PM
I think they designed the deck on my GT 5000 to catch every possible leaf, twig, blade of grass, etc., etc., etc...I just took the top covers off of the deck on the 62' Allis B1 and there was about a golf ball size wad of grass clippings under them. The Sears deck designers must live in the Arctic or in the Sahara.
  • Cat385B said thank you
#14 propane1 ONLINE
propane1
  • 8,726 Thanks
  • 4,132 posts
Posted March 22, 2014 - 07:56 PM
Yes the covers still let grass under the cover. I took one of the covers off mine and could not see any thing but grass. I wonder if some of the grass gets blowin out the front of the deck then blows back up on the deck as you drive ahead. Noel
#15 HDWildBill OFFLINE
  • 8,975 Thanks
Posted March 23, 2014 - 10:30 AM
It does, you can see it go everywhere especially mowing leaves.  The higher the deck the worse it becomes.
I prefer to have all the pulley's, belts exposed so I can clean them when I'm done.  The covers look nice but so often when I pull them off a mower I'm working on there is all kinds of debris and IMO that leads to an earlier failure of the components.
