Starting Issues With The 4041 Simplicity..
43 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted March 21, 2014 - 04:48 PM
Last fall when I was loading up to head up to Daniel "olcowhand's" plowday, the 4041 decided it didn't want to turn over to start and get loaded on the trailer. So I put it back in the shed and it has set there til now and it's time to start mowing around the shop and warehouse, about 2 1/2 acres. I got it up to the shop and got the engine un-bolted so I could lift it up to check the starter out. The power wire from the solenoid to the key switch was shorting out and not letting the power get thru the switch and back to the starter. I also found the Voltage regulator just lying inside the frame at the base of the engine. I will finish repairing the wiring and mount the regulator on the frame and get it all bolted back up Monday when I get back to work.
IMG_20140321_152413_880.jpg IMG_20140321_152424_690.jpg IMG_20140321_152434_152.jpg IMG_20140321_152350_392.jpg
Also found a number on the engine and I wonder what it is for, there is no ID tag on this engine.
There is a few pieces of the engine tin missing which I  have rounded up and will put back on the engine before I drop it back in the frame. And also a couple of the muffler to exhaust manifold bolts that need to be replaced.
IMG_20140321_152450_704.jpg IMG_20140321_152502_196.jpg IMG_20140321_152527_708.jpg IMG_20140321_152543_015.jpg
I also checked on the rear PTO and found that I have everything except the output shaft coming out of the back of the differential.
  • tractorgarden, trowel and boyscout862 have said thanks
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted March 21, 2014 - 04:58 PM
My offer to fix it at my house still stands. Fastenal, St. Cloud, Mn.
#3 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted March 21, 2014 - 05:07 PM
Thanks Cat, if it gets too much for me, I'll ship it your way!! :rolling:
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 21, 2014 - 05:41 PM
Don't stare at it too long :bigrofl: :poke:
#5 olcowhand ONLINE
  • 43,171 Thanks
  • 32,012 posts
Posted March 21, 2014 - 05:48 PM
Brian, with those numbers painted on the engine, and the fact it has a std type alternator instead of the usual "synchrowave"  system most of these tractors came with, I'm inclined to think this is a replacement engine that came off a piece of business equipment where they assigned a number.
  • Texas Deere and Horse, tractorgarden, trowel and 1 other said thanks
#6 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 21, 2014 - 09:33 PM
Im thinking Daniel is right about that.
#7 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted March 22, 2014 - 09:40 AM
I fixed the title so he doesn't have to Stare at it too long! Funny that 2 Mods & an Admin didn't see the error! :bigrofl:
Good luck with the repairs, Brian!
  • Texas Deere and Horse and LTD have said thanks
#8 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted March 22, 2014 - 10:08 AM
I didn't notice, what did it say Kenny?
#9 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted March 22, 2014 - 10:27 AM
"Staring Issues With...."
#10 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted March 22, 2014 - 10:53 AM
LOL, that's funny. I was in a hurry and didn't check everything I guess. Thanks for fixing it. :thumbs:
#11 olcowhand ONLINE
  • 43,171 Thanks
  • 32,012 posts
Posted March 25, 2014 - 09:46 AM
Time for an update Brian!
#12 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted March 25, 2014 - 10:39 AM
Got the engine out and decided it needed a good bath, went to fire up the Pressure washer and it won't start. Rebuilding the Carb on the pressure washer so I can get this engine cleaned up.
Going to fix the manifold bolts while I'm at it.
  • olcowhand and KennyP have said thanks
#13 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted March 28, 2014 - 07:26 PM
Last time I saw a sparkplug with that much rust it was on an outboard I found in the bayou.
#14 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted April 07, 2014 - 08:26 PM
I've got the engine ready to drop back into the 4041. Here are a few photos of what all I did to it while having it out to repair the broken starter wire.
Old air filter verses new filter element.
Old header flanges were warped pretty badly
So I Fabed up a couple new ones.
I put together both headers on the muffler and bolted the flanges down, got everything lined up and tacked them in place. Once I was happy with them, I welded them out.
IMG_20140401_132157_638.jpg IMG_20140401_132208_696.jpg IMG_20140401_134150_558.jpg IMG_20140401_134209_201.jpg
The manifolds were in pretty rough shape, so I machined them with a disc grinder using a new disc and then flat filing with a large Mill File. Also repaired broken and mis-drilled manifold bolts.
IMG_20140401_113918_668.jpg IMG_20140402_085551_080.jpg IMG_20140401_113912_638.jpg IMG_20140402_085559_538.jpg
Didn't have new gaskets so I made a couple out of exhaust gasket material sheet.
IMG_20140401_144424_116.jpg IMG_20140401_144502_218.jpg IMG_20140401_145435_651.jpg
It's almost ready to drop in in these photos, still had some sheet metal to put on it.
IMG_20140401_172018_811.jpg IMG_20140401_172026_675.jpg IMG_20140401_172107_257.jpg
  • olcowhand, KennyP and twostep have said thanks
#15 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted April 07, 2014 - 08:35 PM
Nice work. Is a pic of the whole che-bang coming soon?
