Updates On The Massey!
41 replies to this topic
#16 Cat385B OFFLINE
    Tractorfanatics.com
  • 14749 Thanks
  • 10288 posts
Posted March 22, 2014 - 09:14 AM
Electrolysis.
  • MYMF10 and Gabriel have said thanks
#17 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted March 22, 2014 - 09:45 AM
Your Massey looks good! Keep up the good work!
  • tractorgarden and MYMF10 have said thanks
#18 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted March 22, 2014 - 01:05 PM
The seat pan needs to be strong so maybe you should consider welding in a patch over the rusty area. I'm not familiar with a 10 seat pan so what I'm suggesting might not be practical.
#19 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted March 22, 2014 - 01:15 PM
I just got some body filler called Icing and put it in there im working on sanding it now im gonna see how it turns out here in a bit i will post a pic of it when im done. it seem to pretty good stuff!
  • Gabriel said thank you
#20 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted March 22, 2014 - 01:50 PM
it turned out good! :D its all nice and smooth now!!
  • IamSherwood, Sawdust and Gabriel have said thanks
#21 mavtoy OFFLINE
mavtoy
  • 76 Thanks
  • 96 posts
Posted March 22, 2014 - 05:33 PM
everything looks good so far keep up the good work .....as for using icing my Dad and I use it quite a bit on pitted area's on sheet metal tractor parts only thing we have noticed is if used on non primed metal it tends to let go so priming is a must before hand.
#22 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted March 22, 2014 - 05:40 PM
Thanks ill keep that in mind for next time.
#23 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1295 Thanks
  • 1443 posts
Posted March 22, 2014 - 08:45 PM
Bump! Whats going on Guys?
  • MYMF10 said thank you
#24 Sawdust OFFLINE
Sawdust
  • 6797 Thanks
  • 3799 posts
Posted March 22, 2014 - 08:53 PM
The seat pan cleaned up pretty good. Take it nice & slow & continue to do it right. Your doing a great job so far. I'm waiting on warm weather to paint my MF12. I sand blasted & primed it late last year.
  • tractorgarden, MYMF10 and Gabriel have said thanks
#25 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted March 23, 2014 - 03:56 PM
Finished my hood now its ready for paint! There were some little bumps down by where someone had the muffler sticking out witch melted the paint and the it rusted and then they never did anything about it that kinda made me mad but oh well i got it done and im gonna make sure when i put a muffler on it this time i wont let that happen again! i also got the seat pan smoothed out and sanded it is ready for the bottom side to be primed then that will be ready to paint! Then im gonna start on the axles so i can get this thing sitting on air again! :D :D  The only problem im going to run into is on the spring the is for the variable speed thing!! im not sure how to get that on without scratching any of the paint. Any suggestions on how i could do that??
  • tractorgarden, sacsr, tractorgarden'sbabe and 2 others have said thanks
#26 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 24, 2014 - 08:59 AM
looking awesome. keep the pics coming.
#27 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted March 24, 2014 - 05:38 PM
Okay i have a question about the grill is it a sliver or gray??
#28 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted March 24, 2014 - 08:22 PM
It's suppose to be Silver Mist.
#29 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted March 24, 2014 - 09:07 PM
Okay thanks is there somewhere to get that like would it be at tractor supply??
#30 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted March 25, 2014 - 03:08 AM
Your local Agco deal has the actual color.Not sure what color would be close.Not sure if your going to use your tool box under the seat or not but I've seen people use the spray in bed liner to coat the tool box.Won't scratch as easy as the paint.Just a suggestion you do what you want.
