Bolens Walk-Behinds Using Block Chain
24 replies to this topic
#1 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted March 21, 2014 - 02:29 PM
Anyone have any experience with the older bolens walk behinds that use block chain instead of roller chain? Is block chain still available to buy or is it complelty obsolete? I'm getting a bolens that has block chain an it's pretty worn out I'm guessing I will need to replace it so curious if this is even possible or will I just have to make do with what I have.
  • Bolens 1000 said thank you
#2 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted March 21, 2014 - 03:36 PM
If I am thinking correctly, and "block chain" is the flat chain like is used on hay elevators, then yes it should be available at any farm implement store.
I googled "block chain" and didn't get anything that was remotely associated with what we are talking about!
  • Lauber1 said thank you
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted March 21, 2014 - 04:31 PM
im sure he's thinking flat chain, it has another name but I haven't heard it for so long I forgot it.
#4 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted March 21, 2014 - 04:52 PM
Here is a picture that shows the chain I'm talking about you will probably have to blow it up to really see it gooimage.jpg
#5 classic OFFLINE
classic
  • 6725 Thanks
  • 2700 posts
Posted March 21, 2014 - 05:23 PM
My buddy replaced the flat chain on an old manure spreader twice, so it has to be available. I'll see where he got it and let you know. Someone else may chime in first though.
#6 classic OFFLINE
classic
  • 6725 Thanks
  • 2700 posts
Posted March 21, 2014 - 05:33 PM
Try Evans Implement company, they call it square sprocket chain. Is this it? I just blew up the picture of your chain and yours looks different than the chain this pic. It appears that yours is a laminated type.
Edited by classic, March 21, 2014 - 05:50 PM.
#7 DougT OFFLINE
DougT
    Dog Approved
  • 8377 Thanks
  • 5759 posts
Posted March 21, 2014 - 05:54 PM
It's not the flat implement chain. It's more like the antique bicycles used to use. I always called it skip link chain but not sure what the proper termination is. Aaron's probably right on that. That must be a pretty early DJ to still use that chain.
  • superaben said thank you
#8 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted March 21, 2014 - 06:22 PM
I think that type of chain was called link belt. I've seen it in old ad's, but never in person.
  • trowel and superaben have said thanks
#9 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted March 21, 2014 - 07:19 PM
. Doug, I'm just calling it that because that's what Mike has been calling it. I'm pretty new to these really old old tractors The picture is a bolens model HB. The model D I'm getting has the same chain on it would be nice to find a source for chain when I go to restore it would like new chain if possible
#10 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted March 21, 2014 - 08:09 PM
Glad to hear your getting that model D!
I think you might end up having to build a chain like that. Would be very time consuming but doable. Looks like is mainly flat stock.
Next thing is how wore are the sprockets? If the chain is wore the sprockets have to be.
You might want to hunt down some old machinery jockeys. I've seen chain like that on something but can't remember on what it was.
  • gunstuff1000 said thank you
#11 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted March 21, 2014 - 09:28 PM
Aaron, I am probably wrong about this, but that looks a lot like an older version of what is known as "double-pitch roller chain" Double pitch uses half as many rollers as regular roller chain. Check it out at www.mcmaster.com. The chain they show is not identical, although it looks like the major difference is that where your chain has alternate solid connectors, McMasters has open long  links.
  • superaben and gunstuff1000 have said thanks
#12 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted March 22, 2014 - 12:00 AM
It looks like a Leaf chain with the links in a different order.
#13 Cvans OFFLINE
  • 9625 Thanks
  • 7319 posts
Posted March 22, 2014 - 12:04 AM
Looks like scares chain to me. Very hard to find.
#14 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 6044 Thanks
  • 2247 posts
Posted March 22, 2014 - 09:51 AM
Ive only seen drive chain like that on machinery from back in the 20's and 30's.
How old is that garden tractor, Aaron ?
This is what the  Double-Pitch Roller Chain looks like That Doug suggested  and is available on line from McMaster-car industrial supply.
It comes in pitch length ( A ) of 1", 1-1/4", 1-1/2" & 2".
Roller dia. ( B )   .312 - .400 - .469 & .625.
Roller width ( C )  5/16 - 3/8 - 1/2 & 5/8.
Edited by jdcrawler, March 22, 2014 - 10:07 AM.
#15 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted March 22, 2014 - 01:21 PM
[quote name="jdcrawler" post="432307" timestamp="1395499893"]Ive only seen drive chain like that on machinery from back in the 20's and 30's.
Ray, the tractor pictured is a bolens HB high boy from the 20's. From what I have gathered bolens used that style chain till the early 30's then switched to standard roller chain As soon as I get the tractor I'm getting home I will have to measure up the chain an see if that chain from McMaster Carr is compatible The bolens I'm getting is a model d with the briggs pb engine I think it's from around 1924-1927 somewhere in between there
