Tiller Belt
cub cadet
7 replies to this topic
#1 case1man OFFLINE
case1man
  • 204 Thanks
  • 142 posts
Posted March 20, 2014 - 08:02 PM
Does anyone know where to get a tiller belt for a cub cadet 128. The local cub dealer wants over 100.00 dollars for one. Checked auto parts stores and no one has one long enough. belt size is 13/32x143.8 part number is ih-549250-ri any help is greatly appreciated
#2 boyscout862 ONLINE
  • 13,556 Thanks
  • 9,431 posts
Posted March 20, 2014 - 08:52 PM
I've had good luck with an electric motor shop about 45 minutes from me. Try an industrial motor supply place. Good Luck, Rick
  • trowel and case1man have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 20, 2014 - 08:57 PM
:ditto:  and some of them are in 1/4 inch increments,
  • boyscout862 and case1man have said thanks
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
http://ccspecialties.org/belts.html
Little bit cheaper. You will probably want to go with an IH oem belt. It will last a lot longer and slip less.
Reason for that is: there are specific angles on the pulleys and the IH belt will fit down into them better and grip more.
Edited by LTD, March 20, 2014 - 09:00 PM.
  • boyscout862, case1man and zippy1 have said thanks
#5 tractorskipper ONLINE
tractorskipper
  • 633 Thanks
  • 379 posts
Posted March 20, 2014 - 10:52 PM
I've bought variable drive belts from these guys & got good quality.
Skip
http://www.vbeltsupply.com/
#6 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted March 20, 2014 - 11:17 PM
X-2
  • LTD and case1man have said thanks
#7 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted March 21, 2014 - 09:02 AM
Skip
I've used vbeltssupply lots of times' good prices, fast turn around.
  • case1man said thank you
#8 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 21, 2014 - 02:23 PM
if you have an IH or JD dealership check there I bought my tiller belt for my 1650 from an IH dealership,  same belt just 1/2 the price...
Also tagged with one or more of these keywords: cub cadet
