Jd Weights
9 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted March 19, 2014 - 04:46 PM
Did john deere make a weight that set on top of the engine? Its bolted down it looks like to the head. What might it be worth?
#2 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted March 19, 2014 - 04:54 PM
Yes, it was used on some models with Tecumseh engines.  Which models (Other than the JD112)  & worth I have no idea.
#3 Trav1s ONLINE
Trav1s
  • 3,309 Thanks
  • 4,364 posts
Posted March 19, 2014 - 05:18 PM
The HH100 was only used in the Deere 112's and if my memory is correct the weight was originally for the flat fender tractors which began in 1968.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 19, 2014 - 05:55 PM
Did the tecky have so much compression and power that it needed additional weight to hold the head on?
  • superaben said thank you
#5 grnspot110 ONLINE
grnspot110
  • 4,152 Thanks
  • 2,644 posts
Posted March 19, 2014 - 06:34 PM
Two theories: vibration dampener &/or help stop blown head gaskets.  Personally, I would come nearer believing the vibration dampener!  ~~  Lowell
#6 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted March 19, 2014 - 06:39 PM
As I understood from people "in the know", it was only for vibe dampening.
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 19, 2014 - 06:47 PM
Here is what it looks like:
I believe it weighs around 30-35lbs.
#8 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted March 19, 2014 - 06:50 PM
As you know already they did make one.As for value I have bought then anywere from $25.00 to $75.00 and seen them sell for more than $100.00
but just never know what the next one will bring ,high or low
#9 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 19, 2014 - 07:06 PM
So was it only an option then?  What was the reasoning behind putting it on the engine head?
Ben W.
#10 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 20, 2014 - 04:09 AM
Ben W.
