140 Hd Air Cleaner
5 replies to this topic
#1 Dieselcowboy OFFLINE
Dieselcowboy
  • 72 Thanks
  • 109 posts
Posted March 18, 2014 - 08:24 PM
Does anyone have a picture of a HD air cleaner on a 140? How it is connected to the carb? Any other info on this topic is good also. Thanks
#2 Trav1s OFFLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 18, 2014 - 08:36 PM
The HD air cleaner worked on the square fender 110/112/120/140 machines.  The same basic canister assembly was used on ??? brand golf carts too.  Hapcoparts.com makes the adapter to bolt it to the Kohler carb if you don't want to fab up the piece.  Here is a thread on WFM that talks about details.  http://www.weekendfr...html?1392291885
http://www.weekendfr...html?1394555577
 I plan on doing one on my 312 because I can.  :smilewink:
Edited by Trav1s, March 18, 2014 - 08:38 PM.
#3 Dieselcowboy OFFLINE
Dieselcowboy
  • 72 Thanks
  • 109 posts
Posted March 18, 2014 - 09:52 PM
Kinda wierd but I was thinking of putting the same concept on a C160 wheel horse. I've always been an original restorer but I have 1 wh that is a custom worker. This would be a great add on for it. Already has a JD front axle with 1" spindles instead of factory 3/4".  Thank you for the links, very helpful.
#4 Trav1s OFFLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 19, 2014 - 05:48 AM
I like to restore to originals but am also a "resto-mod" guy from the muscle car world.  I am not afraid to add things that improve usability or functionality.  You might appreciate some of the changes I made to my 120 when I rebuilt it.  The 312 will get similar treatment.  Both 110's will get stock restorations as one was purchased new by my grandfather and the other is a very early '68 side tag.
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 19, 2014 - 07:26 AM
If that setup was available on a stock JD you should be able to find parts diagrams on JDParts.com. It seem to me that I remember seeing it somewhere.
#6 oaktown1987 OFFLINE
oaktown1987
  • 11 Thanks
  • 34 posts
Posted March 29, 2014 - 02:58 AM
I'd get on eBay order a 16 horse air cleaner base and run 16 hp air filter
