Wanted
Custom Steering Help
8 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,079 Thanks
  • 2,369 posts
Posted March 17, 2014 - 05:15 PM
    I want to start another pedal tractor project soon and need some advise. I am going to use a david Bradley hood on a tricycle style framework, want it to look like an old john deer when done.  I have most of the tractor figured out and have most of what I need here, what I am having trouble with is the steering gear box for the front.  I want to put a right angle steering box on the outside of the hood so you see the steering shaft on top of the hood like the one in the pic.
   I cannot seem to find a right angle gear box to suit, needs to be small and light duty, and not cost $250.  Any suggestions???
  • trowel and Sawdust have said thanks
#2 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted March 17, 2014 - 05:27 PM
What about the gear box on a old Sears mower deck. I have a Sears Custom 10E, the deck has two gear boxes, one for each blade.
  • trowel said thank you
#3 olcowhand OFFLINE
  • 38,038 Thanks
  • 30,450 posts
Posted March 17, 2014 - 05:28 PM
Most pedal tractors only turn the steering wheel less than half a turn, lock to lock.  So do you want gear to gear, or slow it down with a worm to gear system?
#4 New.Canadian.DB.Owner ONLINE
  • 2,318 Thanks
  • 1,491 posts
Posted March 17, 2014 - 05:50 PM
How about using the auger gearbox from a  snow blower?
#5 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted March 17, 2014 - 06:09 PM
Cant help with the gear box but here is a link to some bevel gears. Maybe it will help.
http://www.mcmaster....d-gears/=r4ztxj
#6 Bmerf OFFLINE
Bmerf
  • 1,794 Thanks
  • 1,466 posts
Posted March 17, 2014 - 06:46 PM
How about something like this? 1/2 inch drive should be strong enough?
Milwaukee 48-06-2871 Right Angle Drive Assembly
http://www.toolup.co...CFeZAMgod-hYAdA
#7 Sawdust OFFLINE
Sawdust
  • 5,314 Thanks
  • 3,241 posts
Posted March 17, 2014 - 07:24 PM
Thanks Bmerf I had the same idea but on my mobile can't copy & drag links. I have one of those. I think it would be heavy duty enough but small enough as well. You could probably weld a 1/2" socket swivel to get the right angle on the steering rod.
Edited by Sawdust, March 17, 2014 - 07:26 PM.
#8 petrj6 ONLINE
petrj6
  • 4,079 Thanks
  • 2,369 posts
Posted March 17, 2014 - 08:30 PM
   FOUND ONE!!!!!!!!!!!! :dancingbanana: :wave: :thumbs:  gravely mower deck gear box on e-bay $50.  thank's guy's never would have thought of that myself.  will look great on there.
#9 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted March 17, 2014 - 08:35 PM
The petal Simplicity you made is great :thumbs: thanks for showing me, looks great up close.
If you do change the rear wheels to bike wheels and want to sell the wheels let me know.
P.S. i sent you drawings for the headlights via email, was too big to upload here.
Edited by trowel, March 17, 2014 - 08:36 PM.
Also tagged with one or more of these keywords: Wanted
