David Bradley Chainsaw.
13 replies to this topic
#1 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted March 16, 2014 - 02:41 PM
Found a DB chainsaw for sale local. Listed as a 1952 with a 24 inch bar. Unknown if it runs.
I think I want it. Can anybody tell me anything about them? Good,bad or ?????????
Thanks.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 16, 2014 - 02:46 PM
Probably has a Power Products engine.  They are neat lookers, and sure do get attention.
I don't know what size chain it uses, anyone here know?  That's where it can get interesting.
Ben W.
  • trowel said thank you
#3 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 16, 2014 - 04:41 PM
At that age, it would be hard to say without knowing the model, my guess would be .404 chain. Anything can be good for the right price, even if it wont run it would make a good shelf piece.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 16, 2014 - 04:52 PM
Ben W.
Yes and even after Sears phased out the DB saw.
As for the chain it depends on the year and make of the saw, 1/2 inch to 3/8.
#5 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted March 17, 2014 - 06:51 PM
Anybody have one?.
Does it cut well?
I plan on using it regularly if I get it and it runs or will run with minimal work and money.
I cant find any reliable specs on it. Anybody found anything before hidden away on the internet?
Does look pretty neat.
Anything other than vague chain facts?
Would this be considered a two man saw?
From what Ive seen on the youtube it looks to be gear drive. Is that right?
Thanks.
#6 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 17, 2014 - 07:25 PM
I have two, one gear drive, one direct drive they are the later metallic blue ones.
All are powered by the Power Products engine.
Just about all parts are NLA, the gear drive uses the 1/2 pitch chain, the direct drive is 3/8 pitch chain which i used some, both are very heavy and slow compared to modern ''zip'' saws. The gear drive was very slow but ripped out 1/8 strips/chippings and worked all day on a few tank fills.
I would stick to the new saws and save the old monsters for show and tell, with no muffler to call for it will deafen the neighborhood.
The model 360 has become the most sough ofter saw.
Edited by trowel, March 17, 2014 - 07:31 PM.
  • Racerxxx said thank you
#7 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted March 17, 2014 - 07:51 PM
As with most DB items, you have to have a model number to be able to tell much about them. This goes for tractors, tillers, saws and about 50 other items. One of the greatest thing ever done, was Sears had a data base for telling you by this number what the item was. I have a few saw manuals here, but without the model number, its a hopeless task to figure out which of the zillion products it is.
  • trowel and Racerxxx have said thanks
#8 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 17, 2014 - 08:11 PM
917.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted March 17, 2014 - 09:22 PM
917.
:poke: jesse your such a smart xss. Thanks for reminding me the DB stuff all starts with 917. :wallbanging:
#10 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 17, 2014 - 09:25 PM
It happens, just a reminder :smilewink:
#11 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted March 19, 2014 - 07:05 PM
Just got home with it.
Its a model 917.60029
Im off to the internet to find out what I can.
#12 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted March 19, 2014 - 07:08 PM
Just got home and your leaving again?
#13 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 19, 2014 - 09:25 PM
CRAFTSMAN (SEARS ROEBUCK & CO.) ecblank.gifspacer.gif?OpenImageResourceCHICAGO, IL U.S.A.
SERIES OR ASSEMBLY NUMBER:
ecblank.gif917.60029 U4G
YEAR INTRODUCED:
ecblank.gif1965
YEAR DISCONTINUED:
ENGINE DISPLACEMENT:
spacer.gif?OpenImageResource4.7 cu. in. (77cc)
NUMBER OF CYLINDERS:
spacer.gif?OpenImageResource1
CYLINDER BORE:
spacer.gif?OpenImageResource2.0 in. (50.8 mm)
PISTON STROKE:
spacer.gif?OpenImageResource1.5 in. (38 mm)
CYLINDER TYPE:
spacer.gif?OpenImageResourceAluminum with cast iron sleeve
INTAKE METHOD:
ecblank.gifReed valves
MANUFACTURER ADVERTISED H.P.:
ecblank.gif4
WEIGHT:
ecblank.gif24.4 lbs. powerhead only
OPERATOR CONFIGURATION:
ecblank.gifOne Man operation
HANDLEBAR SYSTEM:
ecblank.gifRigid
CHAIN BRAKE:
ecblank.gifnone
CLUTCH:
ecblank.gifCentrifugal
DRIVE TYPE:
ecblank.gifGear reduction
CONSTRUCTION:
ecblank.gifDie cast magnesium
MAGNETO TYPE:
ecblank.gifPhelon
CARBURETOR:
ecblank.gifPower Products diaphragm type, gravity feed
MAJOR REPAIR KIT:
MINOR REPAIR KIT:
AIR FILTER SYSTEM:
ecblank.gifSkinner ribbon filter element
STARTER TYPE:
ecblank.gifPower Products automatic rewind
OIL PUMP:
ecblank.gifManual
MAXIMUM ENGINE RPM:
ecblank.gif4,500
IDLE RPM:
IGNITION TIMING:
ecblank.gif0.175 in. (4.44 mm)
BREAKER POINT SETTING:
ecblank.gif0.020 in. (0.51 mm)
FLYWHEEL/COIL AIR GAP:
ecblank.giffixed
SPARK PLUG TYPE:
ecblank.gifChampion J8J, Autolite A7X, AC M45
SPARK PLUG GAP:
ecblank.gif0.030 in. (0.76 mm)
CRANKSHAFT MAIN BEARINGS:
ecblank.gifBall
FUEL TANK CAPACITY:
FUEL OIL RATIO:
ecblank.gif1/2 pint to 1 gallon = 16:1
RECOMMENDED FUEL OCTANE:
ecblank.gifRegular
MIX OIL SPECIFICATION:
ecblank.gifSAE 30 non-detergent
CHAIN PITCH:
ecblank.gif1/2 in.
CHAIN TYPE:
ecblank.gifOregon
BAR MOUNT PATTERN:
SHORTEST GUIDE BAR SUPPLIED:
ecblank.gif16 in. (40 cm)
LONGEST GUIDE BAR SUPPLIED:
ecblank.gif20 in. (50 cm)
COLOUR SCHEME:
ecblank.gifMetallic Grey enamel
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
COMMENTS:
spacer.gif?OpenImageResourceUsed Power Products AH-47 engine type 1224A. New "UNIT FRAME" design U4G
What I found on the sight I find my info on.
Edited by suburban 12, March 19, 2014 - 09:34 PM.
#14 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 19, 2014 - 09:34 PM
The U model was made for a long while as the cheaper saw, model did not change much so was seen into the late 60's early 70's under Sears and others, there was a bunch of U made with gear drives, they were very good saws and still are.
The tank is a split tank, 3/4 is fuel, 1/4 is bar oil, thumb push manual oiler, carbs were Tilly HL and HT on the early ones, Tech (model # eludes me) carbs on the later ones.
Later ones had baffles in the exhaust defector reducing the noise somewhat.
Chain is usually 3/8 or smaller, 16 inch bar.
Edited by trowel, March 19, 2014 - 09:38 PM.
