Swisher Ride King
9 replies to this topic
#1 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted March 16, 2014 - 10:33 AM
The I&I antique tractor club had an auction/swap meet this weekend.  Bought a Swisher Ride King for the wife's collection. It was an IRWIPI  special. I'm headed for the shop to see if it will run or not.  Rick
  • hamman, sacsr, DB1 and 3 others have said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted March 16, 2014 - 10:45 AM
They sure are a no frills unit. I always thought they were a neat looking machine.      Thanks.        Good luck.                      Roger.
#3 Cat385B OFFLINE
    HAZMAT CAT
  • 14,366 Thanks
  • 10,136 posts
Posted March 16, 2014 - 11:28 AM
Early to mid 80's machine based on the sheet metal and the motor.
  • superaben said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 16, 2014 - 12:55 PM
There used to be someone in my area who used one regularly.  However, I think they upgraded to a ZT.
Is the only drive wheel in the front?
That Tecumseh engine has a hard to find starter on it.  Hopefully the cup the starter engages works well.  I'm still trying to find one for a customer.  :wave:
Ben W.
#5 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted March 16, 2014 - 01:02 PM
Ben W.
Yes the single front is the drive wheel. Spin it around to go in reverse.
This does not have electric start.   (At the moment it is NO START)     Rick
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 14,366 Thanks
  • 10,136 posts
Posted March 16, 2014 - 01:47 PM
When you get it started, be careful. When you twist that handle on the right under the hood, it unleashes second gear. It's like going from impulse power to warp factor two.
Wheeeeeeee!  :rolling:
  • sacsr and superaben have said thanks
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 16, 2014 - 02:03 PM
I'm talking about the recoil starter.  If it is what I think it is, unless there was a different model I don't know about that uses the same body shell with different guts inside, there is a little cast aluminum cup with teeth that break off on the flywheel.  That style went NLA years ago.  I think even George was looking for a starter cup for that thing along the way for a friend.
Ben W.
#8 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
First rider I ever owned, it was called "Big Mow" then.  Mine had the ratchet start, plus 110V electric, you made sure it was close to an outlet at starting time!  Not a bad mower on level, fairly smooth ground, not very good on uneven ground though!  Mowing height adjustment was spacers on the shaft above & below the blade.  ~~  Lowell
#9 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 16, 2014 - 03:11 PM
Those are a nice looking little mower. Don't think I've ever seen one in person.
#10 HANKG OFFLINE
HANKG
  • 6,590 Thanks
  • 3,527 posts
Posted March 16, 2014 - 03:57 PM
I COULD SEE GEORGE JETSON CUTTING THE GRASS WITH THAT RIDE COOL
