* * * * * 3 votes
Bush Hog JBI Diesel Repower (Hogzilla)
792 replies to this topic
#121 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted February 19, 2011 - 01:28 PM
The avatar is neat & so is the diesel JBI. Dan if U or anyone else has machining problems, just ask. I have
been doing it since 10-67 & have done just about everything except cutting gears.
#122 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 19, 2011 - 03:09 PM
Started this morning engineering the pedal hydro control. The OE pedal was inside the dash tower, which even kinda neat, was horribly cramped. I used an original JB pedal, but mounted it out on the running boards where there's plenty of room. The dash as I said earlier will eventually house the battery & fuel tank.
I had to ditch the original linkages & make new. Only part I used was the link rod, which I had to cut shorter, then thread the end for the ball socket. To get the geometry to work without my foot in a severe angle at full speed position, I had to weld a piece of strap steel onto the hydro control arm. You can see if going down to the control rod. There will be no hand hydro control as it had originally.
I took a couple short video clips while driving it, just to show how the engine doesn't hardly know there's any load on a full speed takeoff. Kinda shaky, but tells the tale.
Not hardly any time at all lately to do any work to it, but finally a day off for some progress!Posted Image
Edited by olcowhand, February 19, 2011 - 07:20 PM.
#123 jj69chev OFFLINE
jj69chev
  • 24 Thanks
  • 150 posts
Posted February 19, 2011 - 03:15 PM
Good to see progress again
#124 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 19, 2011 - 03:20 PM
For the life of me, I keep having problems getting the photobucket movie to show & play right here on the GTT pages.
#125 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted February 19, 2011 - 06:33 PM
Who is that kid running around in the hot rod with no hood :bigrofl: Nice progress Daniel on the diesel. I bet you will be plowing the garden with it soon! Nice job.
#126 MH81 OFFLINE
Posted February 20, 2011 - 02:34 AM
Dan, It won't. Photobucket doesn't play well with the forum. If you use Youtube or a couple of others, it'll work ok.
As for the project: :thumbs: :thumbs: :thumbs: :thumbs: (that's 4 big thumbs up.)
Looking great, loving how you're working thru the glitches.
#127 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted February 20, 2011 - 07:48 AM
OOOOHHHHHH! Diesel.! Nice work a little disapointing that there wasnt any black smoke :D
What type of muffler is that and where can i get one?
#128 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 20, 2011 - 09:45 AM
Oh, that's right Alan, I keep getting it mixed up, which one works with GTT. Maybe one day it'll sink into my thick skull! LOL
To get some black smoke, I think I'll have to put the 2-bottom plow on it! That engine is gonna take some pull to make it work enough to blow smoke. Sure does have the power! That is a Kubota muffler, so guess a dealer item.
#129 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 24, 2011 - 10:11 PM
Had just a few minutes to diddle on the JB today. No more driving for a while, as I took the manual steering column out in preparation of installing power steering.
#130 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 24, 2011 - 10:40 PM
What are you going to put back in it? What does your power steering system consist of?
#131 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 25, 2011 - 10:30 AM
As I get into it, I will post complete with pics of the power steering add-on.
#132 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 25, 2011 - 04:21 PM
Had just an hour or less to mess with building a new steering column to work with my orbital valve. I'll get some pics up over the weekend. Other than 3 or 4 hydraulic fittings, I think I have all the rest it will take.
#133 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 25, 2011 - 05:43 PM
Sound good I am curious I would like to put it on mine one day definitely before I put a front end loader on it.
#134 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 25, 2011 - 07:02 PM
On a Case, I think you'll have to add a priority valve to split enough hydraulic for your steering. Not a biggie to do, and otherwise just like I'm doing.
#135 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 25, 2011 - 08:21 PM
Sounds good I will have to keep a close eye on you then!!!
