* * * * * 3 votes
Bush Hog JBI Diesel Repower (Hogzilla)
792 replies to this topic
#511 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 12, 2013 - 06:31 PM
HOLDING HOLDING HOLDING HOLDING HOLDING HOLDING HOLDING HOLDING
#512 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted February 12, 2013 - 06:32 PM
Blue bibs???   That's gray primer.
They are work clothes, aren't they!
#513 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted February 12, 2013 - 08:24 PM
Boy that rig would meld it self nicely into a IH 1066 I think :thumbs:
  • Cat385B said thank you
#514 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,997 posts
Posted February 12, 2013 - 08:33 PM
I was thinking 706........
#515 olcowhand ONLINE
  • 41,020 Thanks
  • 31,379 posts
Posted February 12, 2013 - 08:56 PM
Yeah, might make a good copy of either one, but I'll have the one & only Bush Hog "Hogzilla"!   :smilewink:
#516 olcowhand ONLINE
  • 41,020 Thanks
  • 31,379 posts
Posted February 12, 2013 - 09:04 PM
  Sure does stand well now, you lifted  the front a little. :thumbs:
Here are before, then after pics.  Yes, she has a much better stance, and an full axle tilt under a full lock turn, tires clear everything with room to spare now.
I tried editing the triple quote a couple of my posts back, but it won't let me do away with the one quote box, and wouldn't let me put text above it or below it, so I just made this post instead.
  • KennyP and twostep have said thanks
#517 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,997 posts
Posted February 12, 2013 - 09:52 PM
Well, ya gotta get to 15,802 somehow. By fair means or foul.
#518 Cvans OFFLINE
  • 6,629 Thanks
  • 6,121 posts
Posted February 13, 2013 - 02:33 PM
That tractor does look like a Hoss.  :thumbs:
#519 olcowhand ONLINE
  • 41,020 Thanks
  • 31,379 posts
Posted February 13, 2013 - 05:07 PM
I finished the bumper, got some satin black paint on it, and headlights mounted into it.  Once it cures enough to handle, I'll go ahead & put it back on the tractor.  I ran test wires to the headlights and they are bright!
  I  also welded on 3/8 x 1" ribs onto the front of the bumper to further protect the headlights from damage.
  • Texas Deere and Horse and IamSherwood have said thanks
#520 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted February 13, 2013 - 05:32 PM
Now Hogzilla can see where he's going! Thanks for the update!
#521 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 14, 2013 - 11:27 AM
:thumbs: I finished the bumper, got some satin black paint on it, and headlights mounted into it.  Once it cures enough to handle, I'll go ahead & put it back on the tractor.  I ran test wires to the headlights and they are bright!
Thanks. That was almost 24 hours. I didn't know I could hold that long. :wave:
Looks good, and yes, they're bright. :thumbs:
#522 olcowhand ONLINE
  • 41,020 Thanks
  • 31,379 posts
Posted February 14, 2013 - 07:22 PM
Got my bumper mounted back on the JB, and got the headlights wired.  Took it for a spin after dark, and she lights a big path!  They are 55 watt quartz halogen.
#523 olcowhand ONLINE
  • 41,020 Thanks
  • 31,379 posts
Posted February 16, 2013 - 02:10 PM
Done a couple things to Hogzilla today.  First, I made a cover plate for behind the bumper, which will hide the wires, headlights, and horns.   Then, after driving & finding that the diff lock lever didn't stick out far enough for easy engagement, I built a pedal to slip over the 1/2 shaft.  Welded a steel bushing to the plate, then drilled & tapped for an allen set screw.  Plenty of room left and will make for easy use off the differential lock.  Likely about all I'll get done today, as afternoon chores begin soon.
#524 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted February 16, 2013 - 03:42 PM
What kind of a transaxle are you using that has a Diff lock?
What were they used in?
#525 olcowhand ONLINE
  • 41,020 Thanks
  • 31,379 posts
Posted February 16, 2013 - 03:51 PM
This hydro/diff came out of a Simplicity Sunstar, and is the exact same system as under the JD430 diesel.   The hydro is Sundtrand model 15, coupled to a Tecumseh Peerless 2600 series, with Hi/Lo range & diff lock.
