* * * * * 3 votes
Bush Hog JBI Diesel Repower (Hogzilla)
792 replies to this topic
#436 olcowhand ONLINE
  • 42,368 Thanks
  • 31,793 posts
Posted January 27, 2013 - 10:22 PM
Daniel, Your neutral return system is a great piece of engineering. Nice Job.
You never told me about being run over by your Hog, We can ever be too careful.
It's somewhere in one of my threads about my being attacked by my own tractor.  I went to start it standing right up to it.  I felt the pedal & thought it was in neutral.  It was only parked a couple or so feet from my well house, and the throttle was set just slightly above idle.  It t fired up & immediately grabbed my left calf, and took my knee almost to the ground, but then the front of the tractor went against the well house, while the tire spun against my calf.  Then I pulled my leg out from the tire & all was fine, other than a scraped red leg.  Had Redwing leather boots on, so they saved my foot.   Each tire was fluid filled and had 80+ cast weights on each.
  • Cvans said thank you
#437 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted January 27, 2013 - 10:29 PM
I have been Thankful for wearing good boots several times. :thumbs:
Glad you had yours on that day!!
#438 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 28, 2013 - 12:47 AM
Nicely done on the neutral return setup. :thumbs:  I assume you left the arm longer, with a hole in it
so you can add a helper/tensioner spring if desired?
#439 olcowhand ONLINE
  • 42,368 Thanks
  • 31,793 posts
Posted January 28, 2013 - 05:58 AM
Sharp mind there Will!   Yes, in case actual working conditions require helper springs, I can add one easily.
#440 olcowhand ONLINE
  • 42,368 Thanks
  • 31,793 posts
Posted January 31, 2013 - 10:20 AM
Hopefully when I go to town after lunch, one of the two hydraulic parts shops will have the fittings I need in order to hook up my power steering & cooler lines so I can drive this beast & test out my new hydro system soon.
#441 olcowhand ONLINE
  • 42,368 Thanks
  • 31,793 posts
Posted January 31, 2013 - 02:47 PM
Got the fittings!  Now that I have them, cold weather is back.   :(
#442 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted January 31, 2013 - 02:49 PM
But you DO have heat. :thumbs:  Get to it MAN.   :tapping_fingers:    We want video !! :watch_over_fence:
:bigrofl: :bigrofl: :bigrofl: :bigrofl: :bigrofl:
  • IamSherwood said thank you
#443 KennyP ONLINE
  • 40,123 Thanks
  • 46,764 posts
Posted January 31, 2013 - 03:45 PM
It was warm earlier today, then the North wind picked up and it's downright chilly out there. Hope to see the tractor moving about soon!
#444 olcowhand ONLINE
  • 42,368 Thanks
  • 31,793 posts
Posted February 01, 2013 - 03:26 PM
Was 10F this morning, but got to 20 at noon, so I just threw open the door & spent the last 3hrs piddling around. Real men don't need heat! :smilewink:
 I got all the hoses attached, and the Simplicity's 23x10.50/12 turfs mounted for now.  No pics or video until I get some manly looking tires back on it.  As large as this JB is, these small turfs look weird on it.  Hydro works fine, but oil is pretty stiff, so steering is still slow.  The neutral return is too abrupt, so I put the shift shock on it.  Now it's too stiff to return at higher throttle settings, but I can't dial it in until warm weather when the oil is up to a good warm temp.  Got to working at a front bumper, which will also have integral headlights,  Not enough done to post pics of yet.
  • Texas Deere and Horse, IamSherwood and KennyP have said thanks
#445 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 01, 2013 - 03:32 PM
Oh, looking forward to the bumper with lights. :rocker2:
That should be nice.
Too bad about the cold.
Can't you just block up the back end, let the hydro run, and warm up the
oil?
#446 olcowhand ONLINE
  • 42,368 Thanks
  • 31,793 posts
Posted February 01, 2013 - 03:37 PM
oil?
I hope the bumper comes out looking good....time will tell.  I could warm it some, but things will work as well as when it truly warm outside, so I'll just wait on refining the neutral return.  It may even be fine once the weather warms up real good.
  I had thought about putting the headlights in the front of the hood, but it is angled to the center & would have been tricky for me to make it work AND come out looking good...... I'm no Ray, aka jdcrawler!
#447 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 01, 2013 - 04:05 PM
I like the idea of having them in the bumper
#448 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted February 01, 2013 - 11:20 PM
Don't sell yourself short, I've seen some of your Fab work in person. :thumbs: Lights in the bumper will look great when your done. :worshippy1:
#449 KennyP ONLINE
  • 40,123 Thanks
  • 46,764 posts
Posted February 02, 2013 - 04:06 AM
I'm with Brian, here! You do good fab work and this should look good when you get it done.
#450 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted February 02, 2013 - 06:25 AM
Can you use one of them shock dampers from these new hydros like say , one off a box store JD ?
You may not even need it if the oil was warmed up?
