* * * * * 3 votes
Bush Hog JBI Diesel Repower (Hogzilla)
792 replies to this topic
#391 KennyP ONLINE
  • 37,511 Thanks
  • 45,514 posts
Posted January 21, 2013 - 12:14 PM
I knew cleaning would take a back seat! Once these kind of things are done, than you can clean!
#392 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted January 21, 2013 - 02:28 PM
Looking good Daniel, You are moving right along with it.
I have located one of the hubs and am trying to remember where the other one is. :wallbanging:
They are 1 1/8" bore with 1/4" key way all the way thru. :thumbs:
  • olcowhand said thank you
#393 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 21, 2013 - 02:39 PM
THANK YOU my GTT Brother!   :dancingbanana:   That really simplifies things for me.  You'll find it I'm sure, as you have plenty of time to think on it.  I am in no rush for the hubs.  For now I'll just put the simplicity wheels/tires on this JB when I'm at the point to moving it around.
#394 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 21, 2013 - 05:50 PM
Got everything done farm wise early, so I got time to pull the hydro apart.  I swapped the swash plate pins to put the control shaft to the left side of the tractor, then reversed rotation by flipping the charge pump housing 180 degrees, and slicing the grooves in the valve plate on opposite sides.  It now has the grooves in both directions, and I'm not sure if this will cause slight drop in pressure or not, but I guess I'll find out.  If it does, then I'll have to contact Sundstrand for a proper valve plate.
In the pic below, you can see the shorter cuts I made, vs the longer factory grooves.
here are general pics of apart, then back together.
  • Texas Deere and Horse, IamSherwood, KennyP and 1 other said thanks
#395 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted January 21, 2013 - 06:05 PM
You didn't clean, you just covered up the mess!
:watching_you: :oh_shucks:
#396 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 21, 2013 - 06:11 PM
Yep!   :rolling:
#397 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 21, 2013 - 09:06 PM
Thought I would add to this hydro service.  Some may wonder why I didn't mention making a gasket.  Most times when I take a hydro apart, I re-use the old gasket even if it came apart on both halves.  I am careful not to disturb the gasketed surfaces during my work.  Once all the service work is finished, I spray the damaged gasket surface with carb spray to remove oils.  Then I lightly blow with air to quickly dry the carb spray.  If any oil remains, it will show up as a wet spot.  Simply spray with carb cleaner again, then blow dry till it is oil free.  Then coat both surfaces with Permatex MotoSeal 1.  Let tack a couple minutes, then bolt everything up tight.  I have yet to have a leaky hydro doing it this way, but I only use this method one time.  If it does leak, or I have to take it apart again for another reason, I will either cut a gasket or purchase a new one.
#398 Cvans ONLINE
  • 6,467 Thanks
  • 6,059 posts
Posted January 21, 2013 - 09:43 PM
Pretty hard to argue with success. I am a big fan of the "forma a gasket" materials. They also seem to make it easier to take apart again if necessary.
#399 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted January 22, 2013 - 04:36 AM
What are the specs on the Sundstrands? Pump vs. Motor ? And psi at max? Not the charge pump.
#400 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 22, 2013 - 09:08 AM
Hope the pic shows clear enough....edited;  Split it into 2 larger pics.
  • Texas Deere and Horse and skyrydr2 have said thanks
#401 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted January 22, 2013 - 11:16 AM
Very nice, thanks Dan.
#402 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted January 22, 2013 - 12:54 PM
I havent seen cuts like that in the valve plate. All the ones I have seen are like a triangular scoop. I do have a spare 15 series thick   valve plate  if you need it. I think its the motor plate so its bi directional. Was for a MF1855.
#403 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 22, 2013 - 02:55 PM
I have a spare 15U for parts, but the motor valve plate doesn't match the cutouts in the pump plate.  All previous hydro's I've ever been into had the triangular shaped chamfer also.
#404 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted January 23, 2013 - 06:21 PM
Yesterday I installed the hydro onto the diff & used a drill to turn & prime the system.  All worked as it should.  Today I only had an hour or so to do anything to the JB.  So I beefed up the left side where the differential attaches.  The right side is boxed factory, but the left was just the 1/8" metal side & not rigid at all.  I added the C-channel, and 1/4" plate below it where the diff bolts up.  The nuts are spot welded in place to make bolting up the differential much easier.
 I will weld a plate over the open rear of the C-channel, & may also add gussets at the front later.
  • Texas Deere and Horse and sacsr have said thanks
#405 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted January 24, 2013 - 12:22 PM
That will definitely stiffen up that side. Glad you are finding a little shop time every day or so.
