* * * * * 3 votes
Bush Hog JBI Diesel Repower (Hogzilla)
792 replies to this topic
#361 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted January 15, 2013 - 06:16 PM
And Kenny, I've not mentioned that I also have to get into the hydrostat to machine an angled relief into the pump drive plate ( required for reversing rotation), grind down a reverse limiting bump down, and likely swap the rock shaft pins so the direction control arm will be on the left side of the tractor, where I will be relocating the hydro control pedal.
  Yeah, "might" get it all done!   :hitting_self_roller:   This will most likely be my last major project involving so much modification.  After this is completed, I'll likely stick with easier resto work or simple mods.
#362 KennyP ONLINE
  • 38,310 Thanks
  • 45,901 posts
Posted January 15, 2013 - 07:16 PM
Sounds like lots of fun. Just enjoy doing it!
#363 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 15, 2013 - 07:18 PM
Sure you will. I for one, am not buying that. It's in your blood mister.
But if you're serious, will you be selling your plasma cutter? :smilewink:
This does look like a major undertaking, but you'll get it done.
  • olcowhand said thank you
#364 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted January 15, 2013 - 08:17 PM
Well, for the 1st line of your quote......you may be right!   :D
2nd line........... NO!  :rolling:
3rd line.....Yes, unless something takes me out, I will finish.  Just not sure when, but I'm never sure as to "when" on anything.
#365 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 15, 2013 - 09:07 PM
"When".........
My guess, would be, sooner than you think. Now that it's all over the shop floor, you'll get tired of
walking around it. :thumbs:
#366 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted January 15, 2013 - 09:19 PM
"When".........
Those are wise words for sure!  Especially being such a small shop.  Before I do anything more, a lot of stuff has to find another home for a while so I can just walk easily if nothing else.
  Another thing I've not mentioned is needing to build rim adapters.  I need them at least 1" thick, and bolt to the 5 bolt hubs, then machined to allow bolting up my 6 lug rims.  Never build adapters before, but willing to try.
#367 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 15, 2013 - 09:30 PM
I was wondering why every time I hit view new content tonight my :bs:  meter was getting pegged. Finally found the culprit.
:thank_you:
#368 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted January 15, 2013 - 09:39 PM
Now be easy on me guys, as this project is gonna kick my butt!  Likely it will be quite some time after this before I'd attempt much of anything else.   Like Kenny said, I have to keep it fun, or the drive will leave me.  I do like a challenge, but I'm biting off a lot this time.  It's not like I'm doing anything so difficult, but the time constraints make it even more of a challenge.  But being I'm at home when I'm at work, I can steal a half hour project time at various times during a typical week, that helps a bunch.
  • Texas Deere and Horse and KennyP have said thanks
#369 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,499 posts
Posted January 15, 2013 - 10:45 PM
Daniel Is there any reason not to change the centers of your rims to 5 lug?
#370 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 16, 2013 - 01:33 AM
That's a good idea Brian. Sure would save alot of drilling and tapping.
http://www.millertir...12-rims-convex/
#371 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 16, 2013 - 02:39 AM
We'll go easy on you. I am amazed you have found the time to even start back on this. What an interesting build this is! Good luck Daniel :thumbs:
#372 KennyP ONLINE
  • 38,310 Thanks
  • 45,901 posts
Posted January 16, 2013 - 04:42 AM
Guess just changing the hubs would be a bit of a challenge. Adapters should work!
#373 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted January 16, 2013 - 05:06 AM
Zing your rings for the adapters and send them to me and I'll poke the holes in them in a heart beat! And quit your whining and get to it! You've done WAY MORE than I would have though already !!"! ;)
  • olcowhand and KennyP have said thanks
#374 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted January 16, 2013 - 11:45 AM
The center hole in the rims is too large to allow for re-drilling the rims.  I also need to also kick out the wheels at least 1", so I need a spacer plate too, and I'd not want to use long bolts with the spacer as it might cause twist.  An adapter which is bolted to the hub, then tapped for the rim lug bolts would be much stronger.
It'll be some time before I get to that point, but I'll keep that in mind!  I'd likely hate for you to see what I would cut out.  Likely be rough as a cob.  I can turn the outer edges in my lathe, but no chuck large enough to true the center hole.
#375 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted January 16, 2013 - 06:32 PM
On the Trojan Horse I drilled out the welds for the centers and welded them back for the correct offset. Was kind of dreading it but went good and took less time than expected. Welding the holes left from drilling the welds was the biggest hassle and that wasn't a big deal.
